Ford made a change in 2 Dr tops ?
Rydfree
Benny
Alabama
My '23 2Dr Badlands has been at Town & Country Ford in Bessemer Alabama since November January 13th. I dropped it off then to have the 2nd replacement top put on, but when they went to install it the locater pin and all mounting holes were in the wrong spots. The newest one that should have been installed today has the same issue. They tell me there is no distinction in the part numbers so all they can do is try again, but they cannot find any information that ford has made a change in the mounting design. This all seems strange to me. It looks like I will be without my Bronco for a min of a month and that's if we get lucky and the next one fits. I have a trip coming up Feb 14th weekend and will be really P.O'd at that point if it still has to sit there, Has anyone heard anything about a design change ?
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
Id tell them you need your vehicle and when they get the correct top in youll bring it back. Its not a safety concern so they dont have any grounds to keep it.
Rydfree
Rydfree
Benny
Alabama
It doesn't have a top. They had the glass removed and installed in the new top then started scrapping my old top before they found out it would not fit . Believe me , if it wasn't either 12 degrees or raining out I would just go get it.
Lowcountry Bronco
William
South Carolina Lowcountry
My '23 2Dr Badlands has been at Town & Country Ford in Bessemer Alabama since November 13th. I dropped it off then to have the 2nd replacement top put on, but when they went to install it the locater pin and all mounting holes were in the wrong spots. The newest one that should have been installed today has the same issue. They tell me there is no distinction in the part numbers so all they can do is try again, but they cannot find any information that ford has made a change in the mounting design. This all seems strange to me. It looks like I will be without my Bronco for a min of a month and that's if we get lucky and the next one fits. I have a trip coming up Feb 14th weekend and will be really P.O'd at that point if it still has to sit there, Has anyone heard anything about a design change ?
You sure they ordered for a 2 door and not a 4?
edit ... nevermind ... if the glass fit ...
@Ducati1098 could probably help you out.
ChrisB351
Shreveport, LA
Didnt think about that.. Good luck.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Ducati1098
M2DZ-98502G33-AA was replaced by M2DZ-98502G33-CC, but this was back on 11/15/22
It doesn't tell me what was changed, but I would be extremely surprised if the locator pin location was changed... that means they would have to change the whole body i would guess.
Ford Bronco Ford made a change in 2 Dr tops ? 1738095514258-w1
Ducati1098
Rydfree
Rydfree
Benny
Alabama
Yep the glass fit and was the 1st thing I had asked. You would think the order would be tied to the VIN but I have no idea.
Lowcountry Bronco
William
@Ducati1098 is now a courtesy shuttle driver, picking up and driving B6G members around all over the USA?
Wow, and I thought he was super helpful before! 😁
I was thinking that he might be able to give them the correct p/n, but if he's giving rides ...
Ford Bronco Ford made a change in 2 Dr tops ? 1738095702162-5w
Rydfree
Rydfree
Benny
Alabama
It doesn't tell me what was changed, but I would be extremely surprised if the locator pin location was change... that means they would have to change the whole body i would guess.
Yeah that's what's strange to me. It doesn't make sense that the hole locations have been moved on the body itself.
Ducati1098
Actually now that I think about it... It's impossible that it wont fit, or that the pin locations are different
Because you cant even order the old part number anymore, It's been replaced by the new one. So that means the original part number and the new one have to mount the exact same 🤷‍♂️
Otherwise Ford would make some type of note saying something else needs to be replaced to make the new part fit.
604Bronco
British Columbia
www.bronco6g.com
YOU'RE WELCOME @fordmotorcompany
Don't forget to request folks to DM you their VIN on every post you offer assistance on.
Joking aside, this post would be a lot better if we had some pictures to see what the issue was. I assume the dealership didn't provide any? Would be surprised if they didn't take any though.
Ford Bronco Ford made a change in 2 Dr tops ? Screenshot 2025-01-28 at 12.51.12 PM
Ducati1098
Yeah pictures would be nice.
But regardless, I think there’s only 3 4 possible scenarios
1. Dealer somehow ordered a 4dr top
2. Dealer ordered the correct top, Ford sent the wrong top.
3. Dealer is lying about it not fitting for some reason 🤔
Edit: 4. I guess it could be damaged and not lining up also, but that wouldn't really explain why they said the locating pins have moved.
