Ford modified soft top to prevent paint scratching roll bar
flip
Phil
IN
www.ruxerparts.com
Fords
Sorry for my ignorance, but does a TSB give a resolution to the issue, are dealerships to implement a fix before a vehicle is delivered, or is it just an FYI of a known issue?
Technical Service Bulletin. Not a recall, just a “fix” if a vehicle exhibits a certain issue. Sometimes it’s build date driven or from a certain plant. The fix is putting felt on certain points on the top frame. Didn’t read the whole thing, just looked at the tech instructions quickly before leaving work.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
This is what got me. Not sure Velcro will fix it. They kinda need to shorten these screws or use rivets.
Ford Bronco Ford modified soft top to prevent paint scratching roll bar 69E9760E-0298-4737-8E4F-7F7E75BA3DFB
Ford Bronco Ford modified soft top to prevent paint scratching roll bar 5E0F7BEF-4599-4A9F-A8FE-90FD4FB10ACF
Ford Bronco Ford modified soft top to prevent paint scratching roll bar 0F3322FE-F966-457E-84D5-1B799F27C493
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Glad someone is pointing out the actual problem.
Daktari
Oliver
I bought the PPF and will inspect mine closely once it finally shows up (maybe this week?). If there is felt applied I'll just keep an eye on it, especially once it gets hot again here. If it moves or falls off I think I'll use the high heat felt tape that's used on my Big Green Egg bbq, that glue should easily hold at what ever temp the interior gets in summer, as it hasn't melted on my BGE at frequent over 500F. Certainly should work better than the sticky felts for chairs that always come off.
Mhenry303
Fort Myers, Florida
2021 Ford Bronco Big Bend 4DR Area 51
Has anyone seen a company making the roll bar covers for the bronco like they make for jeep?
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
Exactly what's happening to mine. Does anyone know the TSB Number for the fix?
coupon_ninja
Abby
VA
2017 Ford Mustang GT, 2021 Jeep Rubicon 2D
I took mine down ever-so-carefully last week and… chip. twice @&$! It was a late Nov build
coupon_ninja
Abby
VA
coupon_ninja
Abby
VA
I think I’m gonna bring this up to my dealer, as well as the poor paint job in my door hinge areas. I ordered the ppf from iag though. AND I already have a bottle of touchup paint 🤓
