Ford modified soft top to prevent paint scratching roll bar
Headsong
I didn't realize that until recently. Also explains the absence of grab handles over the doors
To which I call BS! My Tundra has both airbags AND grabhandles in the front posts.
Headsong
BroncoKong Jr.
Andrew
Ah, yeah. But why not the A-pillars? That's all you need usually....
It's a very common accessory on Jeeps. Since the Bronco doesn't have a-pillar handles, I had been wondering why there were no overhead accessory ones until I found out it's because of the airbags.
Mikesmallcrawler21
TN
14 F150 screw
Is PPF really gonna protect the paint long term, when in a situation where the issue is constant rubbing from vibration? Or is the damage happening from raising and lowering the soft top? I figured PPF was good for incidental contact... not for constant rubbing...
BroncoKong Jr.
Andrew
The damage seems to be only from raising and lowering the top
bytheway
Brice
Louisville, KY
604Bronco
British Columbia
www.bronco6g.com
There’s a TSB that just came out to address this.
Sorry for my ignorance, but does a TSB give a resolution to the issue, are dealerships to implement a fix before a vehicle is delivered, or is it just an FYI of a known issue?
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
I had already bought some felt tape to address this....Oh well I can beef it up more.
LOL, yeah me too. I bought some from Amazon as soon as people started reporting it. :)
JohnnyBronco
Pennsylania
X4
What about plain old pipe insulation ? And plastic handcuffs or duct tape You? You only need to protect the top and the added thickness might help with rear side window sag. Or more pricey dedicated roll bar wrap that comes in colors to match.
I would doubt that the actual air bag sensors are in the rail and Takata explosive power should be enough to blast through whatever you cover roll bars with
