- Thread starter
- #1
This might be why they trademarked G.O.A.T.
https://pdfpiw.uspto.gov/.piw?docid=10315481&SectionNum=1&IDKey=9B26721B4FEB&HomeUrl=http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2%26Sect2=HITOFF%26u=%252Fnetahtml%252FPTO%252Fsearch-adv.htm%26r=1%26f=G%26l=50%26d=PTXT%26p=1%26S1=(%2522Ford%2BGlobal%2Btechnologies%2522%2BAND%2B%2522dynamic%2Bsuspension%2522)%26OS=%2522Ford%2BGlobal%2Btechnologies%2522%2BAND%2B%2522dynamic%2Bsuspension%2522%26RS=(%2522Ford%2BGlobal%2Btechnologies%2522%2BAND%2B%2522dynamic%2Bsuspension%2522)
The 2021 Ford Bronco's Suspension May Rock Babies to Sleep, Dance to Music
Oh, and there's even a "Daredevil" suspension mode—provided this patent is for the Bronco.
Nick Yekikian Apr 14, 2020
We're eagerly awaiting the new 2021 Ford Bronco, the resurrected 4x4 whose scheduled reveal this spring was pushed back by, well, global events. But hey, we're stuck inside and antsy, so we went digging to see if we could turn up any of the Bronco secrets Ford is holding close to the vest. (After all, we had luck dredging up renderings, factory paint colors, roof design details, transmission specs, leaked photos, and more. ) A newly discovered patent has given us our latest morsel of Bronco goodness: It suggests the new Ford SUV will have a very intricate terrain-response system and a (very) active suspension setup.
The Ford patent describes a complex mating of hardware and software that essentially links the Bronco's (possibly optional) electronically adjustable suspension system to a monitoring setup tracking traffic, weather, terrain, and even what kind of music you're listening to to determine the car's optimal ride height and suspension behavior. It works both on the fly, automatically, and at the behest of the driver, via several apparently driver-selectable modes.
The system, at least in patent-filing-speak, is called Anomaly Mitigation Suspension Mode, and while it isn't assigned specifically to the Bronco, there's almost no chance it's destined for any future Ford product not named "Bronco."
We aren't sure if A.M.S.M. is what this intricate setup will be called when or if it is ever officially launched. Perhaps not coincidentally, Ford also trademarked the term "G.O.A.T Modes," which is described as "drive systems comprised of automatic controls for vehicle chassis and powertrain controllers, integrated as an integral part of a passenger vehicle." While you might be familiar with G.O.A.T's popular sports meaning—Greatest of All Time—here it could well be a play on words pertaining to, um, actual goats. As in, goats are quite good at climbing and handling harsh terrain. Obviously Ford's trademark indicates an acronym, but for what, it doesn't say. Perhaps it means "Go On Any Terrain," or "Get Over Any Terrain?"
Whatever it is ultimately called, it sounds as though the system will be on almost all the time and capable of changing the Bronco's right height depending on what kind of surface it's driving on, suggesting that whether you're on normal roads or sand dunes, the system will be finding ways to optimize ride height and suspension characteristics. The patent also mentions off-road specific features, such as lowering only the nose when climbing a steep grade to give the driver a slightly better view forward, rather than staring at a windshield full of sky.
The only image offered in the patent, here we see the four wheels linked to a central control unit that controls the 2021 Bronco's active suspension.
The patent says there are various "targets" that the Bronco's system will use to determine what suspension mode it should be in. (Think of target as another word for variable—these variables are constantly monitored, fed back into the car's brain, and the ride height is optimized accordingly.) Targets include the type of terrain the car is on, how much traffic there is around you, the weather at your location, what kind of fuel economy you're trying to achieve, and which drive mode (separate from the suspension settings, like, say "sport" or "eco") that you're in.
Once the vehicle understands its context—very existential, Ford!—it settles on one of the many, many suspension modes described in the patent. Some have rather bland names and purposes, but a few practically jumped off the patent filing, such as Entertainment Mode, Music Mode, and Daredevil Mode—no, we aren't making these up. Entertainment mode monitors the driver's "non-traditional" inputs to determine which of the other two modes—Music or Daredevil—to activate. Music mode will set or fluctuate the car's ride height to match whatever's coming out of your speakers. It sounds like, but we can't be sure, this might bump the vehicle around like the active suspension in Mercedes-Benz's GLE-Class SUV. The intent there, other than having fun and showing off to your friends, is ostensibly freeing the GLE if it were to be stuck in deep sand or snow by jiggling it up and down.
Daredevil mode, according to the patent, claims "the vehicle's suspension height may be mapped to the target suspension height such that the vehicle . . . can be driven on, for example, two and/or three wheels without overturning." While it's probably not for wheelies, or road use in general, the ability to tilt the car over on one side might actually prove useful for clearing narrow off-road obstacles or setting a tire perfectly on a boulder or even balancing a Bronco if one or more wheels lose purchase while traversing particularly egregious terrain. Here are the other suspension modes listed in the patent:
- Mobility (the Avoidance, Traffic, Freight, and City Mobility modes fall under the Mobility umbrella)
- Avoidance (adjusts to deliver quicker responses from the suspension)
- Traffic (basically a comfort mode)
- Freight (sounds like load leveling, in which the suspension accounts for a heavy cargo load)
- City Mobility (sets the vehicle up for "aggressive" driving)
- Cooperative (matches ride height to that of a nearby vehicle to facilitate transfer of cargo between them)
- Utility (the Office, Towing, Cradle, and Rest modes fall under the Utility umbrella)
- Office (a quiet, comfort-focused mode geared toward remote working within the car)
- Towing (optimises the suspension for towing)
- Cradle (no joke, this "assigns a low-frequency movement to the vehicle" to soothe a baby)
- Resting (similar to the office setting, this makes the ride quiet and squishy)
- Suspension Minder (the haptic and safety modes fall under the Suspension Minder umbrella)
- Haptic (driver alerts can be registered by body motions / vibrations induced by the suspension)
- Safety (maximizes suspension stability for safe avoidance maneuvers, similar to "avoidance" above)
- Driver (Novice and Expert Driver functions fall under the Driver umbrella)
- Expert Driver (if the vehicle determines the driver to be more experienced, it sets up the vehicle accordingly)
- Novice Driver (if the vehicle determines the driver to be inexperienced, it sets up the vehicle accordingly)
- Fun-to-Ride (this delivers a "rough ride" for a "fun-to-ride sensation for vehicle occupants")
- Fun-to-Drive (sets up the suspension for aggressive on-road driving)
- Quiet (works "in tandem with, for example, active noise cancellation to reduce road-induced noise and/or detected vehicle vibrations)
- Vigilance Boosting (similar to the Haptic function, this detects driver fatigue and can buzz the car via the suspension to wake him or her up)
