Mike5681
Ohio
More Door Sasquatch
Lift kit part numbers:
M-18000-B1A (two-door models)
M-18000-B1 (four-door models)
The lift kits will be available through the Ford Performance parts catalog in Q1 of 2022, while pricing will be released later this year.
2021 Ford Bronco Gets Two-Inch Lift Kit From Ford Performance
Nov 4, 2021
In recent weeks, a host of aftermarket companies have developed and begun selling lift kits for the 2021 Ford Bronco. Now, the rugged off-road SUV is set to receive yet another lift kit offering – this time, a two-inch kit directly from Ford Performance, Ford product planner of off-road and overland Ford performance parts, Kyle Sargent, told Ford Authority executive editor, Alex Luft, in a recent interview.
The Ford Performance 2021 Ford Bronco two-inch lift kit is manufactured by Bilstein – which supplies shocks for the Bronco’s Sasquatch Package – and is tuned by Ford Performance. It’s designed for use on two- and four-door Base, Big Bend, Black Diamond, and Outer Banks trimmed Broncos but is not compatible with the Sasquatch Package.
The new lift kit consists of massive 2.65-inch mono-tube shocks that are 60mm in diameter, which makes them the largest shock diameter of any production 2021 Bronco. The shocks included with the Sasquatch Package are 46mm in diameter, though those units also utilize external reservoirs, which are not present on the shocks included in the Ford Performance lift kit. Additionally, the kit comes with front and rear coilover springs that are identical, direct bolt-in, one-for-one replacements with those included in the Sasquatch Package.
The Ford Performance two-inch 2021 Ford Bronco lift kit includes these components for both the front and rear and both have been tested and confirmed to provide superior performance and durability.
The part numbers for these new lift kits are M-18000-B1A for two-door models and M-18000-B1 for four-door Broncos, and it’s worth noting that each is tuned differently. The lift kits will be available through the Ford Performance parts catalog in Q1 of 2022, while pricing will be released later this year.
Mike5681
Ohio
More Door Sasquatch
David196
Pennsylvanian
Chevy Traverse
Wonder why they're NOT compatible with Squatched Bronco's? Something to do with Ford limiting the travel??
This kit comes with the Sasquatch springs already attached.
My guess it would work on a sasquatch, just not needed on a sasquatch. Sasquatch already has a built in lift.
ThunderSquatch
Chester County, Pennsylvania
Bronco BaseSquatch, (ex: RAM 1500 5.7 HEMI 4x4)
Sounds like a Bilstein 6112 with custom valving. That might actually be a good buy if they don’t charge more than what the 6112’s usually cost.
WuNgUn
Ontario Canada
Escape
It does, but it isn't 2" over the non-Squatched Bronco's, pretty sure.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
If you're suggesting +2" to a base is more than the +1.2" for the Squatch shocks, then yes.
Travel range numbers would be interesting to know.
(Edit): @North7 - think these are the one the Bilstein engineering was hinting about? I thought there were to be 6200 variants that are adjustable with reservoirs using the Squatch springs.
lakesinai
Charleston SC
Yes, it is explained elsewhere on this forum, and Im not going to try when more knowledgeable people can do so, but it has to do with articulation travel limits that are included in Sasquatch, and also explained in the discussions of 37" tires, and how its easier to upgrade to 37s from the stock trims than from Sasquatch, counterintuitively . . .
KEM IA
Kevin
Cedar Rapids
Tundra
Wonder if Bilstein will have shocks that have adjusted heights for stock springs?
North7
North Texas
Non-Ford
Looks like my sources were correct back in May, but of course Ford never keeps a schedule, so it looks like they have slipped to "Q1 of 2022".
More intel on the upcoming Ford Performance shocks I learned about at last weekends Bridgeport event. While at the 4WP show in Dallas yesterday I spoke with the Bilstein rep and he told me he was working with Ford on a "new project". He said they will be available though Ford Performance, as I heard from the Ford Performance rep last week.
It involves their model 6112 unit and it will be a drop in replacement for use with the Sasquatch springs as these springs are "Barrel design spring" that work well off-road. The Badlands springs or the standard model springs will not work with this part number. You have to imagine they may also make a second part number available with the springs for those coming from a non Sasquatch model.
I told him I had heard about them from the Ford Performance rep who said they would be ready by Q3 but he said more like Christmas (North7 connects the dots).
Further, I asked if the Bilstein ESCV design they are making for Ford is the same as the 8112 models and he said only in concept as the ESCV's are tailored for a production price point.
Jhuff
J
Toyota Tacoma and DR650
So what effect would these have on a non-squatched Badlands? I'm starting to get confused by all the different suspensions.
