az_dirt
Jay
21 Bad Sas AMB
Not trolling/genuinely curious; what bolt-on/plug-n-play upgrades do you know of that are (much) less than $40/hp @ crank for the 2.7L?
Fair question it appears I am the one trolling here because I do not know (apologies). This morning when I typed that, I was thinking that $33/hp would be mind blowingly fantastic for drag racing, for the bronco would I notice? I don't know. Sounds like good reviews so far + warranty, will be watching them. Thank you for the call out.
GotWake
Tony
Whipple? $950 for 50 hp. I mean you don’t get the warranty. But, that wasn’t the question. :)
Cable Guy
Kurt
Audi RS7
VR Tune $750 for 50hp/50+ ft-lb of torque and it is a piggyback so it doesn’t flash the ECU. If you remove it the dealership will never know it was there. 😉
JFelty
Minnesota
Mustang Mach E
True, I want the transmission shift changes too though.
All I can say is that my Wildtrak drives very differently now that this has been installed. Goin on two days now and I don't really notice the added HP and Torque but I do notice the shifting. It makes normal mode more bearable and Sport mode (my go to mode) more fun!
mpeugeot
1. The Flowmaster High Clearance Axle Back exhaust is worth more than 4 HP and it only costs $135. That stock muffler, while quiet, uses more fuel and costs a fair amount of HP (more than 5).
Rdonohoe
1979 Bronco & 2022 Bronco (ordered)
In my experience the first 1000 or 2 miles returns poor mileage for any new vehicle. Would be interesting to compare early results to similar test after 5 or 10k miles…
0ne
Nate
CO
Flex
I’m sure the stock exhaust has a negligible effect on fuel use and power while that aftermarket “exhaust” is just an expensive piece of barely bent straight pipe with a fancy tip you can’t see that makes the Bronco sound like a fart can 🐴💩💨
mpeugeot
Is +1.5-2.0 mpg negligible? I don't know about a 7.5%-10% increase in fuel economy being negligible.
With the "fart can exhaust" I can average over 22.5 mpg at an average speed of 75 MPH over a 300 mile route through the Texas hill country. My best run averaged 23.5 mpg, largely due to the exhaust. Without the exhaust, my mileage drops to around 20 MPG over the same trip (this last trip was right around 19 MPG) on factory tires 32".
I agree, it's obnoxious, but you are wrong about the fuel use. I don't have any dyno numbers, but you can feel a little more pep in the engine. The factory muffler is excellent from the standpoint of mitigating sound, but it comes at a cost.
0ne
Nate
CO
Flex
I appreciate your perspective, I’ll silently keep getting 19mpg happily in my 2.7 Sas 2door whether I’m hooning 100mph or cruising 55 in the Colorado mountains! Sport mode is my “tune.”
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
So does the dealer have to install this to retain warranty? I cant seem to figure that out....
My dealer service manager makes me shake my head. Ive had to correct him on multiple things, and he just called and said the tune is for 2.3 only. I didnt even argue, I just got his email address and am sending him the links.
Its its something I can install without threat to the warranty I will, otherwise Ill have them do it.
mpeugeot
My 2.7 2 door doesn't have SAS...
Ford Bronco Ford Performance Calibration Bronco 2.7 Tune w/ Procal - Initial Review IMG_20220614_222855
but it does have sport mode.
Blaven
Pennsylvania
Ford performance certified dealer or any AES certified shop. A regular dealership should be able to install it also, if they are competent enough. Or just skip them and just install it like everyone else has so far.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
You should combine this with a Pedal Commander and it think you'll get the best results :) - this way you can really fine tune the throttle curve to your driving style and liking.
Ksjrb03
Tx
F250
Pedal Commander? 😂😂😂
