Dashes mean you leave whatever was there, there. You only need to change where there are *.What do you enter when there are dashes on the Google spreadsheet? Working on windows up via fob.
I thought the X's meant you leave whatever is there.Dashes mean you leave whatever was there, there. You only need to change where there are *.
Both are true. Not sure why they made it confusing.I thought the X's meant you leave whatever is there.
I turned that to enabled yesterday but it didn't work. I wonder if there is another module that needs to be programmed as well.Now, if only there were a way to have them pan down when shifting into reverse...
Much like trying to get the global windows to work on a vehicle that doesn't have automatic up/down windows, I think it's merely a matter of Bronco not having hardware needed for seat/mirror memory functions. I don't know of a trim level that offers it.I turned that to enabled yesterday but it didn't work. I wonder if there is another module that needs to be programmed as well.
I've got it sort of working using the numeric edits (under As Built?). However the front windows partially go up, but continuing to hold the lock button seemed to raise them all the way up. I think letting go of lock too early is wrong. Maybe that won't answer your issue though.I tried programming the global windows up and it only works for the two passenger side windows. I tried doing the manual reset procedure on the driver side windows but still didn't work. Just wondering if anyone else has had this happen to them?
I got my global windows up working on all 4, including I have it set to One Touch. so I press my lock button and release and all my windows go up. If I have time when I get home I will screenshot my settings for you.I tried programming the global windows up and it only works for the two passenger side windows. I tried doing the manual reset procedure on the driver side windows but still didn't work. Just wondering if anyone else has had this happen to them?
If I remember correctly, 04 sets the DRL to amber full time. They will blink as turn signal when headlights are off but won't blink when headlights are on.I have mine set the same way, except I just changed it in the plain english list. But I wish I could figure out how to keep the amber horizontal bar on when the headlights come on also. I haven’t really messed with it, but I’m not sure it’s possible.
Correct, unfortunately that’s pointless without working turn signals at night.If I remember correctly, 04 sets the DRL to amber full time. They will blink as turn signal when headlights are off but won't blink when headlights are on.
