Forscan help requested
wintoon
Samuel
Mexico
Hello everyone.
I don't live in the USA so I did not have a choice to spec my Bronco with a locker. It was either Badlands or Outer Banks with all the creature comforts. So I went with Outer Banks.
I want a rear locker and have been digging into how to get a rear locker.
Now I need some help. If anyone can help out I would very much appreciate it.
What I need is a screenshot of the forscan page for the AWD module settings (or several if there is more than one).
I need this for a 4x4 normal (not advanced) with open diffs on both ends, no sway bar disconnect and 10 speed automatic with 3.73 gears (pretty sure the gears have to be 3.73 with that configuration).
I will compare that to my configuration.
I want to see if I can add a (rear) locker and enable it in the GOAT modes. I have already figured out where to connect the locker.
If I am correct I believe by enabling the correct AWD setting, connecting the locker to the correct point, and changing the hero switch pack, I can "upgrade" to a rear locker integrated into GOAT modes while keeping the 3.73 gearing (I know I will need a new ring gear).
If I am successful I promise to do a nice writeup for anyone else to follow if they wish.
Thanks and regards,
Sam.
wintoon
Samuel
Mexico
Nobody has posted it yet. I am hoping someone with the correct config will do so soon.
NEEDS to be the correct config because I need all other things equal so I can isolate what AWD setting enables the rear locker.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Is there a 3.73 rear locker? Seems the 4.27 gets selected when you choose a locking rear diff.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
There is not.
@wintoon is in Mexico, they don't offer all six trims of the Bronco in Mexico, and of the trims they do offer, they don't get all of the options and upgrades we get here in the US and Canada.
Sounds like he wants to add a locker, and have that locker activate automatically when selecting the GOAT modes as it would with the factory configuration.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Honestly the GOAT modes are over rated. I just flip the lockers on and off manually.
wintoon
Samuel
Mexico
Yes, but one thing I think is great about the GOAT modes is that they don't let you do anything stupid, like using a rear locker at high speeds, something that might happen otherwise.
Also... It will help greatly with my OCD if I can add this as if it were almost as if from factory.
I just need to check with forscan to be able to "enable" the rear locker. If so, there is just 1 pair cable that needs connecting from the AWD module to the locker.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I wish I could help but I have the manual transmission. I hope you get the info you are looking for because I would love to hear if you are able to make this work!
wintoon
Samuel
Mexico
If you have a rear locker please could you still post your Forscan data for AWD module? If we have a few people do this it *might* help to narrow it down, then with a little testing I might be able to figure it out... Please post your config (Base + Rear Locker) as well....
Thanks!
wintoon
Samuel
Mexico
Just FYI, this is the AWD config I need please!
Ford Bronco Forscan help requested 1658880281843
This is OBX 4x4 (not advanced) without lockers or sway bar
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Here is as built data for a Base non-Sas no advanced 4wd and manual transmission. Looks like only one row is different?
703-162-01 0000 0000 0050
703-162-02 0000 0010 0061
703-162-03 0000 0000 0070
703-162-04 0000 0000 0080
703-162-05 0000 0000 0090
703-162-06 0000 0000 00A0
703-162-07 0000 B0
703-163-01 4100 0000 0074
703-163-02 0000 0000 0470
703-163-03 0000 0005 04D0
703-163-04 0000 0000 0090
703-163-05 0000 0000 00A0
703-163-06 0000 0000 00B0
703-163-07 0000 C0
wintoon
Samuel
Mexico
Yes. Thanks. I will try this weekend and test the voltage in the AWD module. I will report back.
With a bit of luck it's as simple as just changing 703-162-02.
Thanks again!
wintoon
Samuel
Mexico
703-162-07 0000 B0
703-163-07 0000 C0
Tim,
Thanks for all the help so far. Any chance you might be able to also post the following values as well please:
Instrument Panel Control Module
Accessory Protocol Interface Module
I am not sure if these make a difference since I do not have the hero switch pack yet...
https://parts.ford.com/shop/en/us/electrical/switches/switch-14759503-1?pdp=y#/sectionId:395088949
Once it arrives (I am told around 60 days or so) I can test the button as well.
Thanks again!
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Tim,
Thanks again!
Ok...can you post the lines you are specifically looking for and I can do that.
