What is now irritating me is that air conditioning recirculation randomly turns itself off in the name of saving the earth... Saving the earth is not worth smelling dead highway skunk!
Highly annoying.Yes the intake door will do this. I’m not sure why either
Or just buy a POS if all you are using it for is Forscan.I spent most of the day Thanksgiving looking into it. Parallels has a Black Friday sale going on right now, and my in-laws spent most of the day yelling at each other regarding politics so I had nothing better to do anyway.
Parallels on the M1 Mac can only virtualize ARM, which means I'd need to run Windows 11 ARM. FORScan only supports Windows 11 x86/64. But Windows 11 ARM does have a virtualization layer for x86/64. So I'd have a Mac that is virtualizing an ARM layer for Windows 11 ARM, which in turn has a virtualization layer for x86/64. So it might work in some strange virtualception sorta way? Not sure, but I might give it a shot.
Alright so it rained today, and I ended up spending the better part of the day trying to get this to work.It looks like they’ve made some progress with that on the latest version.
https://www.google.com/amp/s/www.parallels.com/blogs/windowsgames-m1mac/?amp
I’d download the trial and see how it works…
Eco forces 2WD I believe. That’s why it switches.More of an update on Sport mode on a Badlands. I spent a lot of time behind the wheel today and while driving and switch from Sport to Eco the transfer case switches back to 2H from 4A on its own.
So it appears as though the only time it stays in 4A is when it’s in Sport at shut down and you don’t opt to continue sport on a restart….or that’s all I’ve found so far.
Did you come across this thread?Alright so it rained today, and I ended up spending the better part of the day trying to get this to work.
The good news is Parallels if fricken' slick. I personally haven't used it since 2007-ish. But the new version is super impressive and way better than VMware Fusion. Recommended for anyone who needs Windows running on an Apple Silicon Mac.
The bad news is FORScan doesn't work because there are no ARM drivers for the OBD-II readers. I could get FORScan itself to launch using the Windows emulator, but the reader itself won't connect to the vehicle, and Device Manager says the device doesn't have any drivers.
So back to suggestion @Herbie had. Find a crappy laptop to run FORScan.
Is your engine running when you try writing the protocolsCan someone point me to how to shut off auto start/stop? I tried what the spreadsheet said to do but I get an error at the very end of the write process. Will try again tomorrow but if there is a link for the exact process please post. Thanks.
No. Should I have it running?Is your engine running when you try writing the protocols
Yes?! The engine needs to be running when writing the the Forscan modules. When the process is complete it tells you to cycle the ignition. Just did this 2 days ago
Someone needs to read the FORSCAN tutorial.Yes?! The engine needs to be running when writing the the Forscan modules. When the process is complete it tells you to cycle the ignition. Just did this 2 days ago
Well mine refused to work for the hour I tried to do it UNTIL I turned the engine on and programmed with the engine on. So not sure why that is, but maybe next time I'll try with it off.No. Please for the love of god never write modules while the engine is running. You can, and others have, completely brick modules.
You cycle the ignition on and off by hitting the button without having your foot on the brake. Again, please do not ever do this with the engine running.
