This is a bit off topic. Where do (should) I get Forscan? Which OBDII adapter should I get? What should I expect to pay? I run Windows 8.1. Thank you.
But we don't know if the Raptor will have Sport mode!A Badlands with Sas is just a little bit heavier than a Black Diamond with Sas...I would think there is zero chance that it was safety that caused this....Ford is about to launch an even taller and heavier Bronco with a 450+hp engine.
My dealer said... only ECO for the Raptor.But we don't know if the Raptor will have Sport mode!
Crayola is a good way of describing it. Like in Pontiacs with their My First Dashboard knobs. The Bronco one could look good if they put a bit more effort in the graphics package. I complain about this a lot in my business. We have techs that setup touchscreens...techs are not graphic artists! I do like the clean look above. Doesn't feel overwhelming with info. Of course, not sure how the UI is.I don't like the Crayola design of it no. It's just a very odd theme overall for this vehicle. It would be much more fitting with this vehicle to have something like this. I don't even like my 2021 F-150 digital cluster the theme is overall just very soft. Clearly it's a future theme they will be continuing with though. Comparing components on paper in the workshop manuals it would appear the cluster would bolt in. The bezel is the only issue but I imagine it would plug up and "function". I'm sure some quirks will exist as well but would love to look down and see this.
And this is likely something that can be "adjusted" in Forscan. If it were me, I would probably want to set it higher (especially in a "Baja" type environment). I also dislike that the front locker will dis-engage above 20 MPH, but it does protect the mechanicals by doing so. I wouldn't change that, however that's why I am going with the Truetrac differential that works at all speeds.The sway-bar automatically re-connects at 20mph....
I swapped the Torsen for a Wavetrac in my Raptor years ago and it was wonderful. I've heard great things about Truetrac as well. The Wavetrac design allows lock up even with a zero load condition which was definitely proven when I took it through dunes and mud
Is is same driving experience as Baja on 2 wheel driveJust added sport mode to my Badlands. Its better than I expected. This will def impact my MPG lol
Good question. I would like to know this too. I test drove mine in Baha Mode (in 2 Hi) and didn't think it was very applicable for street driving. It held gears to long in my book. Needs a happy medium....Is is same driving experience as Baja on 2 wheel drive
Perhaps 2.3, or even 2.7.Hypothetically speaking, say you're really really thirsty, how many LITERS of water could you drink in a day?? 3? 3.5??
It's been covered, they're different. Baja much more aggressive than Sport.Good question. I would like to know this too. I test drove mine in Baha Mode (in 2 Hi) and didn't think it was very applicable for street driving. It held gears to long in my book. Needs a happy medium....
Be careful what you ask for. If past experience is any guide, Ford will plug this loophole up in an upcoming software release and will most likely take the position that you have voided your warranty if anything even moderately expensive crops up. If you're going to do this, at least make sure you will actually drive the car like this before you do it, so that you actually get something out of your short-lived hack.
Let’s here about this “past experience”. This should be good.Be careful what you ask for. If past experience is any guide, Ford will plug this loophole up in an upcoming software release and will most likely take the position that you have voided your warranty if anything even moderately expensive crops up. If you're going to do this, at least make sure you will actually drive the car like this before you do it, so that you actually get something out of your short-lived hack.
