- Jared
- Jul 14, 2020
- 210
- 1,258
- 1,860
- South Florida
- Website
- www.lethalperformance.com
- 2020 First Edtion 2.7L / 2020 Shelby GT500 CF
- Raptor
Hey All,
Proud to announce the entire FOX Racing Shock line-up for the 2021 Bronco is now available for purchase here at Lethal Performance.
With 2 Series choices for those looking for slight vs moderate lift, the FOX Performance Elite shocks give amazing ride and increased performance for your Bronco to ensure you get the max out of every bit of Bronco.
FOX Performance Elite 2.5 Series shocks for the new full-size Ford Bronco are designed and engineered by off-road enthusiasts to enhance comfort, maximize articulation, and increase compliance in the dirt. You also gain 20% more travel over the stock shocks.
FOX's progressively wound springs provide extra clearance and movement to unlock your Bronco’s entire range of usable travel in both jounce and droop positions. These springs were specifically chosen to compliment the Bronco’s IFS design to offer a uniquely soft ride and better control through rough terrain.
The shocks’ 2.5-inch aluminum bodies and external reservoirs efficiently dissipate heat by increasing internal oil capacity, while the remote reservoirs with Dual Speed Compression (DSC) adjusters are strategically mounted to clear aggressive mud tires and leave space for aftermarket skid plates and bumpers.
Easily adapt your shocks for load, environment, and driving style using the DSC adjusters as the large capacity dampers manage stability through all types of terrain. Additionally, you have a generous amount of preload adjustment to maintain your Bronco’s ideal ride height while supporting a wide range of essential added gear.
FOX shocks provide the versatility required to navigate backcountry terrain on the weekend and tackle your daily commute to remain comfortable and in control.
Features:
- 2.5” impact-extruded and CNC-machined 6061-T6 hard-anodized aluminum body
- Application-specific, custom progressive springs
- 7/8” hard chrome-plated steel shafts
- Vehicle-specific valving to maximize performance
- 2.5” smooth bore and honed seamless alloy reservoir with Dual Speed Compression (DSC) adjuster
Benefits:
- Unlock all travel available in jounce and droop positions
- Maximize comfort and control through any terrain
- Remote reservoirs are mounted to clear larger tires and aftermarket parts
- Maintain optimal ride height with wide-range preload adjustment
- Provide a 3” lift for Sasquatch Bronco and a 4” lift on a non-Sasquatch equipped Bronco
- Soft, progressive springs enhance articulation and increase stability
DUAL SPEED COMPRESSION (DSC) ADJUSTER
Add remarkable versatility and precise tuning with Fox's DSC adjuster. A simple twist of either two adjuster knobs allows 10 separate low-speed and 12 high-speed compression levels. Included new black anodized aluminum reservoir increases cooling efficiency.
Fox Racing 2.5 RR Elite DSC Front Adjustable Coilovers (2.5-4.5" lift) (2021+ Ford Bronco 2-Door) 883-06-192
*Requires Upper Control Arm
(Sold as a PAIR with all needed mounting hardware for both shocks and reservoirs)
Check them out here below!
2 Door Sasquatch and Non-Sasquatch
4 Door Sasquatch and Non-Sasquatch
Fox Racing 2.5 Remote Reservoir Elite DSC Front Adjustable Coilovers (2-4" lift) (2021+ Ford Bronco 4-Door) 883-06-195
Fox Racing 2.5 RR Elite DSC Rear Adjustable Coilovers (2.5-4.5" lift) (2021+ Ford Bronco 2-Door) 883-06-193
Fox Racing 2.5 Remote Reservoir Elite DSC Rear Adjustable Coilovers (2-4" lift) (2021+ Ford Bronco 4-Door) 883-06-196
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Features:
Benefits:
Extended | 23.720 |
Compressed | 17.940 |
Travel | 5.780 |
Top Mount | OEM |
Bottom Mount | Bar Pin |
Extended | 26.420 |
Compressed | 19.440 |
Travel | 6.980 |
Top Mount | OEM |
Bottom Mount | Bolt |
