Like anything else, it depends. Are you going to use your Bronco in a way that makes it advantageous?
I am not. Even though I use 4WD on a weekly basis, I do not need or want it. If the sway bar is an issue, I will remove it altogether, likely with no ill effects, as can be done on most 4WD vehicles. For me, it would be a wasted gimmick. For others though, it may not be and could be very useful.
I have no desire to pay for stuff I know I won't use, especially expensive to fix stuff. Most likely, my Bronco is not going to roll on stock springs/shocks for long and will probably have a slightly higher spring rate and sway bar delete.
