Sway bar disconnects can be useful, but as you can see there are opinions on both sides. If you are not doing some significant (tough) off road driving then you would never likely have a need for them.
Yeah, it's located behind the axle, looks like alot of crawling around in the muck. My Jeep is in front and has that open front fender-no problem.I don’t know man, I could be wrong, but to me it looks like you really got to get under there to reconnect it. Even with the jeep I often have to get in there with a crow bar to pop the second link on. Maybe being an IFS will be easier. I’m sure aftermarket will come up with a solution if it’s a problem
Where you will really notice it is on those trails with diagonal drainage cuts. You can switch on the disconnect, speed up the trail to each cut, slow down, and then the suspension will ease over the cut one at a time without nearly as much rocking back and forth. Then speed back up again.Im getting a badlands but the main reason im getting it is for overlanding and i see it as the most capable.
However after watching several videos of the "disconnect" feature that makes the badlands unique. I have to wonder if its all that impressive or even useful (very small articulation difference).
Will we really not know until the car is out? Or so some of you with IFS experience off road know better? Is this going to be a big deal of a feature or kind of a gimmick?
They are simple to add as it's just an end link & usually you only disconnect them at the beginning of the trail and reconnect them at the end. I got tired of doing this and tossed them both on my XJ. Ran 10+ years without them. Driving styles my varyI’m not sure how easy it will be to add manual disconnects, to me it looks like they would be hard to get to. The Jeeps couldn’t be in an easier place, but they can still be a pain on uneven ground and it always seems to be wet or muddy if you have to crawl under there to do it. With that being said if didn’t look very impressive in the video clips but hoping it’s more practical when actually using it.
