ZROADZ Front Bumper LED Mounts and kits are a quick and easy way to add forward facing lighting to your Bronco. The simple bolt on installation uses factory bolt locations and provides significant auxiliary lighting. Typical installation time is under 30 minutes and can be successfully installed using common hand tools by even the most casual enthusiast. ZROADZ Front Bumper LED Mounts are available in complete kits with light and wiring harness, or as brackets only for mounting common and popular LED light bars. ZROADZ Front Bumper LED Mounts are designed and made in USA.
Features & Benefits:
- Front Bumper Top LED Kit
- Sold as a complete kit, Includes (6) 3 Inch White ZROADZ LED Pod Lights, mounting brackets, wiring harness with fusible link, relay, toggle switch and all necessary hardware
- 1712 Lumens, 20 Watts, CREE 5W LED Chips per pod light
- Flood Beam, IP68 and IP69K Protection Rating, 50000 Hour Life Span
- Mild Steel
- Easy, bolt-on installation, no drilling required
- Low-gloss textured finish
- Limited lifetime product warranty, 3 year warranty on the finish
- Manufactured by ZROADZ Off Road Products in Corona, California. Made in USA
- Also available as bracket only, see part number Z325431 or with amber and white pods Z325431-KITAW
- Fits Heavy Duty Modular Bumper Models Only
- Does not block factory Bronco Grille letters
- Does not block factory front view camera
