Front Camera Question
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Hey folks,
Those of you with a front camera - Just curious if it activates automatically while parking and getting close to a wall or another object? I'm picking up my Bronco tomorrow, and have a fairly tight garage, where I'll need to pull up close to the wall. One of my previous vehicles had a front camera as well, which activated when getting close to something. Just curious if the Bronco is the same, or if it's primarily for off-road use?
If it doesn't automatically turn on, is it very quick to activate it or do you have to fumble through multiple screens?
Thanks!
Daktari
Oliver
it does not, but you can hit the camera button on the dash and it'll come on, front and top down view. Only at low speed, but I use it quite a bit in narrow spots, very useful.
604Bronco
604Bronco
British Columbia
www.bronco6g.com
So the camera button is on the main screen at all times? That's not too bad; pretty handy for sure.
Thanks very much!
FlyingBronco
The Don
Orange County, CA
Thanks very much!
It’s a physical button below the screen, clustered with auto-start on/off as well as parking sensor on/off. I use it whenever pulling into my tight garage, as well.
604Bronco
604Bronco
British Columbia
www.bronco6g.com
Oh right - I remember seeing that... Duh. I'm so used to everything being on the touch screen! That's even better!
Sandbergo
Jelani & Dave
Orlando
Rogue
There is a button next to the auto start/stop button, I haven’t seen it turn on automatically but it seems to shut off once you hit over 5MPH, I am wondering if there is a setting with Forscan to allow it to be on whenever you hit the button.
