- Thread starter
- #1
Driving around with my windows partially down they shake like their about to break when I go over a bump or pothole. Anyone else experiencing this or are my windows loose.
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.Driving around with my windows partially down they shake like their about to break when I go over a bump or pothole. Anyone else experiencing this or are my windows loose.
Watch that video, do it yourself, it literally takes a few minutes. Use an extended 10mm so you can push forward on it as you tighten it because their is resistance that pushes in the opposite direction on the clip so you need to add pressure at the same time as you tighten the nut. The long 10 mm will give you the ability to apply forward pressure on the ratchet with the fingers of one hand while tightening with the other hand. You'll see what I mean.Yup mine rattles pretty hard when down around 3-4". I thought it was just the nature of a frameless window until I saw another post about the service bulletin. But seeing some have had it made worse I don't think I will bother taking it in.
Yup watched the video. I'm guessing it's best to push them all the way outwards?? Or is this an adjust/test/repeat thing?Watch that video, do it yourself, it literally takes a few minutes. Use an extended 10mm so you can push forward on it as you tighten it because their is resistance that pushes in the opposite direction on the clip so you need to add pressure at the same time as you tighten the nut. The long 10 mm will give you the ability to apply forward pressure on the ratchet with the fingers of one hand while tightening with the other hand. You'll see what I mean.
