codydb19
Cody
Silverado
Well that placement looks a little better than what we’ve seen before, but still...
Ford Bronco Front license plate placement on Antimatter Blue Base Bronco 1613963936713
Toccoa
Isuzu Rodeo Sport
Ford Bronco Front license plate placement on Antimatter Blue Base Bronco 1613964364093
Philly
Dallas, TX
2022 JL Rubicon
They are definitely moving in the right direction! Hopefully the final version is something easily removable without permanent holes in your paint.
DonM
Don
Northern Cincinnati
Thank goodness we don't need a front plate in Ohio anymore!!
Username_not_found
Minnesota
Fiat 500 Abarth
Does this one look like it only mounts to the bumper and not to the body? If it just bolts into pre-existing bolt holes on the bumper at least it makes it much easier to run a front bumper until a better solution comes from the aftermarket without worrying about putting permanent holes in the body.
Laminar
Iowa
Cougar
Is it mounted that high because of the active air vents below it? Looks terrible
On the 2011-2014 F-150, the V8 got its license plate right in the middle of the bumper:
Ford Bronco Front license plate placement on Antimatter Blue Base Bronco 1614003926885
While the EcoBoost version had its license plate off to the side to allow better airflow to the intercooler:
Ford Bronco Front license plate placement on Antimatter Blue Base Bronco 1614003963573
I'd wager it's something similar on the Bronco since both engines will have an intercooler there.
Ford would make bank on upgrades to the Modular bumper if one of its features was "alternative license plate mounts."
