Front Parking sensors quit working after installing my LOD front bumper?
Mirage
Huntsville, Alabama
'23 2Dr BL SAS Green/White, '24 2Dr HEL Yellowstone
Not super concerned if they get fixed or not, but after I installed my LOD front bumper a couple of weeks ago, my front parking sensors just didn't work anymore... My rear ones still worked after installing a steel rear bumper, but my front ones no longer work.
No big deal, I just didn't worry about them, until I lifted my Bronco, an additional 2.5", a week later? The sensors just started freaking out, as soon as I started to move, in either direction! I disabled them on the screen, but they still freaked out the screen, as soon as I started to move... I eventually got all that noise/warnings turned off in Forscan!
I'm about to add a new front bumper to my wife's in a couple of weeks and prefer to not have the same thing happen with hers....? Yall got any, non-smartass theories, that'll help me get mine fixed? I noticed something in Forscan about with how high each corner was in mm, I assume, and was wondering if I had to change that number, due to the new lift?
Thanks for any help!
Freebird32
Harold
97 F150 4x4, 82 Toyota 4x4 orig owner, 08 Z06
Did you contact LOD for help? Did you have ACC? Harness swap from old bumper to new, sensor connectors oriented to left or right (not vertical)? LOD should be able to answer your questions, since they designed it..
I just installed a BAMF winch bumper and had to take portions of harness sheathing off to increase pigtail reach on one sensor but they all worked fine after I adjusted outer sensor outward angle to match OEM bumper (21 degrees). Until I did that they were going off anytime I got close to even a car next to me. I didn’t have any lift on mine.
Mirage
Mirage
Huntsville, Alabama
Yes, I've contacted LoD... I installed everything exactly like they said too, pe their
JEMSA
Phoenix
70 Bronco, 82 F350, 91 MX5, 93 MX5, Bronco
I installed warn bumper using stock harness and sensors. Was very wonky until I re-plugged the wonkiest of the four and the main plug as well.
Then back to normal compared to the OEM set up.
Also found my ACC relocation would drop out of service and removed 2 louvers in front of it, though the instructions said the louvers could be left in place . No issues after I pulled those louvers.
TerryB
Terry
Banning, CA
24 Badlands Sasquatch, 2019 Jeep Wrangler Rubicon
Let’s start with the first issue. If the sensors didn’t work at all then you had a connection issue wirh the wiring. Not plugged in, not plugged all the way in, broken wire, shorted wire, etc.
For the second issue it sounds like the lift is pulling on the wiring cable and causing an intermittent connection.
There is no, oh here’s your problem answer. Start at the bumper and follow the wiring looking for connection problems and/or a wire bundle stretched too tight.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
The sensor plugs are very tight. Spray with a bit of WD40, let it dry some, and then replug. They may not be seated properly. It was a problem for me too until I found prior threads.
the wire harness could also be installed in reverse. I did that too… 🤷‍♂️
5GENIDN
Joe
Idaho
I am still running stock bumper and sensors have not been touched.... They are about 9.5 to 10 inches higher than they were stock though and they work exactly as they always have....
Just a guess here... Maybe it was unplugging then replugging them in???? Maybe try a reset by disconnecting the Battery for 10 min.??? Short of that working I would be rechecking all of my connections for the 43rd time.
Mirage
Mirage
Huntsville, Alabama
The lift didn't affect the wiring harness of the sensors... It's not a huge concern, I just have to take the wings off the bumper soon and thought I'd try to figure it out... I've never needed "parking" sensors in my whole 49 years of life and wish it didn't have them...
TerryB
Terry
Banning, CA
WD40 (the original stuff) is an insulator, do not use it on a connector (Or as a lubricant). Within a few months it will turn into a gummy mess and attract dust and dirt. Just look at the door hinges in a house where it was used as a lubricant. That’s what that black around the hinge is from.
If the poster meant WD40 Contact Cleaner, it won’t hurt anything but I see no purpose either. Connectors are supposed to be tight.
Mirage
Mirage
Huntsville, Alabama
It's weird though, because I changed the rear bumper a couple days after owning it and everything worked out fine. The harness cannot be installed in reverse on the front, the rear harness, however, can be installed in the opposite direction. I'll check it out when I get a chance too. Got to work on the wife's Bronco now :) Thanks for the tips!
Mirage
Mirage
Huntsville, Alabama
I have electric contact cleaner that I will use.
TerryB
Terry
Banning, CA
You don’t know that. It’s actually a very common problem after lifts on any vehicle when already tight cables are over-stretched.
Mirage
Mirage
Huntsville, Alabama
Not sure? They never worked at all after I installed the front bumper, but then after the lift, they went insane... Only reason I was curious is, because I was going to take the wings off the bumper soon, and figured that would be the best time to check.
But as soon as I moved, all 4 of them would light up, but with nothing even close to the Bronco, and at different levels of alert and something like green in the middle left, red in the middle right, yellow in the outer right and red in the outer left and just beeping like crazy!
I've never owned anything with front "parking" sensors, so I really don't need them, LOL! I like the rear sensors though and they still work, as does my front camera!
Mirage
Mirage
Huntsville, Alabama
I do know that, because I installed the effin thing and the wiring harness for the front sensors was never touched!
TerryB
Terry
Banning, CA
Some people just can't be helped.
