Front Splash Guards/Mud Flap will NOT fit with Running Board
Bdisco
Flashing my lights behind you, CT
‘88 911,‘15 Chevy 2500, ‘17 Mazda CX-9(wife’s)
Vehicle Showcase
Can confirm the Ford Accessory Front Splash Guards do NOT fit with the factory running board/side steps.
The running board tends to collect a lot of debris from the all terrain tires. I foresee slush and winter crud piling up. Might have to go after market like Rek Gen https://rekgen.com/collections/truck-mud-flaps or something...
  • Not compatible with Rock Rails
Advertisement
Swacer
PA
2014 SVT Raptor; 2018 Shelby GT350
I'm skeptical of that, because if you go to the rear mudflaps of the same style, it also says that its not compatible with the running boards.
....the rear mudflaps have nothing to do with the running boards....
I'm sure there is a way to make them fit. You need the mudflaps simply to catch rocks from hitting the sides of the truck. I put flaps on my '14 raptor and it was a paint saver.
Bdisco
Bdisco
Vehicle Showcase
The Ford Accessory Rear Flaps fit fine with stock bumper and the price is not bad. Side steps do not interfere with them. The predrilled holes do not line up with the holes left after removing the little sasquatch winglets without modification though.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Did you actually order them and try? I have a badlands and am very curious.
Bdisco
Bdisco
Vehicle Showcase
Yes, I need to return them to my dealer. The running board comes too far forward.
Swacer
PA
Any picture? Just wondering if it can be modified at all?
AKBronc49
Russ
Anchorage, Alaska
This was brought up with the Gatorback mud flaps, all you have to do is remove the running board end cap, cut off an inch or two and re-install. it will look factory but provide you enough clearance.
JohnZi
Piotr
British Columbia, Canada
www.instagram.com
Bronco Badlands '21
Do you think Rek Gen mud flaps will fit bronco? I see some universal version but I'm afraid rockrails will be obstruction in this case. The gatorback from ford has some precut holes.
KANE COUNTY ILLINOIS
SAL
GMC YUKON
Thanks! I ordered front and rear mud flaps from Granger's Parts Department and they were going to install them once my Bronco Big Bend w/Ford Side Steps once it leaves MAP's lot! I guess not, right!
JGee
Traverse City MI
2020 Explorer
thanks I will give it a try.
OB121
Bay Shore
2019 Expedition 2021 Bronco Outerbanks Sasquatch
Any updates. I really need these bad for my outerbanks sasquatch. Going to order them and either flip sides or trim the running board length. Have a 3/8" blue stone driveway and rocks flying out for awhile every time after leaving the driveway.
Bdisco
Bdisco
Vehicle Showcase
I returned the Ford rigid splash guards. Did not want to cut my new running boards or hack up the new flaps. I reached out to rek gen and they don’t have anything for the Bronco yet. I have not checked with rally armor yet.
Do need to do something before slush and snow season.
amccue90
Andrew
Illinois
2021 Badlands
Bumping hoping someone found a cheap solution for those with running boards or sliders
Bdisco
Bdisco
Vehicle Showcase
Rally Armor’s response below:
The Bronco is an application we intend to develop. There are a few projects ahead of it at the moment so we'll add you to our waiting list.
Kind regards,
Rally Armor
Bdisco
Bdisco
Vehicle Showcase
rekgen’s response:
We don't have any custom fitting mud flaps for the bronco yet. We are working on getting a bronco in to get some mud flaps fitted and available on our website. I don't have a time frame when they will be available but we are working to get them on as quick as we can! Let me now if you have any other questions.
Advertisement
Lethal Performance
Advertisement
