Front tie down anchor ideas
Barsa1000
Kentucky
Fusion
Ideas for the front 150 lbs tie down anchors?? The prototype shows that they used for vegetation clearing. Which, tbh I'm not so sure it is that useful...
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
Hang your socks on them after testing out the fording capabilities?
securitysix
Oklahoma
2011 Toyota Tundra
Depends on where you wheel, I suspect. Limb risers are probably not needed as much in, say, Arizona as they would be in a place that has trees. Heck, I could benefit from them in my driveway.
Barsa1000
Barsa1000
Kentucky
Fusion
I guess the more I think about it, the more I can see how they can be used cut and push tree limbs out of the way.
But what about other functions for the anchor points? I'm sure an aftermarket company is already designing brackets to mount a massive light bar across the hood.
Or even a mount for a high lift jack.
Imissmy1996bronco
2022 JLU Rubicon
The tie downs are mounted to the fenders, not the hood, so that wouldn’t work unless you wanted to pull the light bar or hi-lift every time you pop the hood.
Barsa1000
Barsa1000
Kentucky
Fusion
Yeah, I guess you can't open the hood with anything you attach to the anchors.
Petey
Minnesota
Honda
Maybe similar to this, but directly on the front of the hood at the tie down points?
crowdpleazer
Daniel
West Virginia
Ford Ranger, Honda Civic
Twin remote fire machine guns. Just used for mowing down vegetation (zombies).
