I’m about to install a few items - a Brandmotion camera mirror and a GMRS radio. The mirror (5A 12V tap) comes with the needed fuse taps and I figured that taps might be a good way to go to power my GMRS radio (15A 12V tap) because I want it tied to ACC, not direct to the battery. I’m looking to source a tap for the radio as well. So far I have a few questions.
1 - Both of these items have different amp/voltage requirements. Am I ok to put the taps in any slot that has an equal or higher amp rated fuse and can a pigtail “rated” to 12V be ok to cover the radio that could potentially pull up to 32V as long as the proper amp fuse is used (operates normally in the 12V range)? Or should I try to find a 32V tap with a 15amp fuse?
2 - which direction do the taps need to be inserted into the fuse box? I assume the current follows this diagram:
