Cobrafang
Thomas
GA
Do you all recommend moving any of the + connected leads off the factory bus setup to the dual system? I am asking without looking at my factory setup first....so this could be a dumb question. But I am lazy and don't want to walk to the garage. :angel:
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
Thumbs up for a positive first post and involvement for us Bronco folks. On my wishlist for our overlanding build :)
74Bob
Bob
Broomfield CO
'22 Bronco, '11 F150 FX4 Eco, '06 Mustang GT
I am curious if the batteries are tied together what would be the total CCA of the battery setup? Under hard winching conditions the winch could pull upwards of 500 amps at stall so will the buss bar handle this high of a load? My old '74 Bronco runs a pair of group 27's to power the Warn 8274 and I have never had an issue winching under near stall conditions.
I like the idea of dual batteries and it looks like this setup would fit the bill nicely.
LangleyBen
Ben
Langley, BC, Canada
2024 Bronco Badlands Sasquatch
Looks like each Odyssey battery is pretty close to OEM spec, but now you have two of them:
OEM BatteryODYSSEY Battery
Part #BAGM-94RH7-800ODP-AGM25
Web LinksWebsiteWebsite
Cold Cranking Amps (CCA)800 CCA765 CCA
Weight50.5 lbs50 lbs
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Hello Bronco6g forum! I'm Shane Smith, the owner of Genesis Offroad. I made this video to give you a quick introduction and a look at our dual battery kits for the Bronco. Our kits fit all 3 engine options in the Bronco, and we keep all our parts in stock all the time for the fastest shipping time in the industry!
Learn more about our easy to install dual battery systems here - https://www.genesisoffroad.com/gen3-bronco-dual-battery-kit.html
Got questions? We're here to help! Please reach out to us here, or by phone - 901-214-5337 or by email - [email protected].
Thanks guys, I look forward to talking to you!
Can you suggest the best Dakota Lithium Starting batteries to use for this setup?
genesisoffroad
genesisoffroad
Shane
Olive Branch, MS
'21 Bronco
Like I said, for powering something for an extended period of time, like a fridge, this system doesn’t seem like the best solution. It’d be much more effective to hook a DC-DC charger directly to the starter battery and have a dedicated battery bank in the cargo area.
That's certainly an option. Of course there's always pros and cons to every option. One down side to doing that is just the issue of taking up space in the rear cargo area for the battery, and the extra wiring involved. But if space isn't a priority, then nothing wrong with doing that. Our customers like the simplicity of installation with putting 2 batteries side by side under the hood, but to your point, the battery size is constrained by the amount of space we have available, which for the Bronco, the Group 25 size battery is the largest size we can shoehorn in there.
genesisoffroad
genesisoffroad
Shane
Olive Branch, MS
'21 Bronco
We'll be doing some testing with Dakota Lithium soon, stay tuned!
genesisoffroad
genesisoffroad
Shane
Olive Branch, MS
'21 Bronco
Short answer is no. For a more detailed answer, please check out this clip of this topic in our Top 9 Questions video here -
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
those are excellent batteries…made in USA as well
Br0nc0_Badlands_Sasquatch
Drew
The Moon
N/A
Finally, a clean solution for running an isolated battery system on the Bronco platform. This gives me a comfort to move forward on the fridge and camp lighting setup knowing I can start the vehicle in the morning in case I pass out ;-)
for what it's worth, the Bronco will turn itself off to save the battery if you run it for too long
jalawson
TX
‘22 Bronco, ‘17 F150
genesisoffroad
genesisoffroad
Shane
Olive Branch, MS
'21 Bronco
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
I think he's asking about the leads connected directly to the battery, not the AUX switches that are addressed in your video. The Bronco has 3 studs on the positive terminal available for wiring (IIRC).
