Dmorty217
Derek
Venice FL
Camery
My bronco arrives the end of this month, so I can’t enter but will be purchasing a double rod holder
Nemo
Ceres, CA
99 F250
I'm in.
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 20220506_181839
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Very interested. Is there any way to lock or secure them in the holder for highway driving? It'll be for bait casters down here in Texas
A bungee cord does the trick. It's how we've been holding rods to the holders for years. We didn't invent the plastic rod holder. Those have been used on vehicles for years upon years. You usually see them built into cooler racks on the front/rear hitch points on trucks. Just slide the rod holder in. I've never lost one yet but I like to throw a bungee cord on so it can't accidentally fly out.
That's why we left an opening in the bracket, so you can throw a small bungee cord around the rod/reel.
DrewBronc21
New York
2020 Subaru STi, 2024 M2
I will def get a pic up and buy these regardless. These look like a great rod holding solution for topless Bronco Especially since fitting a one piece 11ft surf rod with a large saltwater spinning reel in a 2 door Bronco will be a challenge.
As someone who fishes the Surf on LI frequently, the only improvement I would like to see is for holders to be made out of steel and lock around the reel foot to prevent theft. My Lefty VS Van Staals aren’t made anymore and worth more than anything else I would have in or on my Bronco lol.
Allfun
Paul
Lowell, MA
2017 F-150 STX
Not one of my surfcasting rods, but a rod nonetheless. Thanks for doing this!
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) E314CB7E-3678-4DF6-98A4-73D5FDFDB010
PrincipalD
Ryan
Sioux City, IA
Expedition, Bronco
Just picked up yesterday. It will be our fishing rig!
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 617DD9A2-F05F-498B-84F7-0E121933B4A6
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 6209D717-6CD9-42E9-AD89-5EDEF21E626D
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
This is an absolute must have for the River trips here in the PNW. No 2 piece poles here! Thank you for being the first to make the holder!
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 0FFD1E4B-4227-4BD4-A29B-EF5299DAB984
Tight lines
Jersey shore
Dodge 2500 ram diesel , Ford edge ST, 67 Firebird
We're going to be giving away a FREE Fishing Rod Holder Kit from KR Off-Road.
Rules are simple! Post a photo of your Bronco with your fishing pole resting against it and you are entered!
We'll choose one random winner on Friday, May 13th at 5pm (EST) who will win a Double Rod Holder Kit from KR Off-Road.
We'll also choose a runner-up who will win a Single Rod Holder Kit from KR Off-Road.
Your kit will ship once we finish production on these (ETA: June 3rd)
https://www.4x4truckleds.com/kr-off-road-fishing-rod-holder-for-2021-ford-bronco/
If you're a fisherman looking for a place to mount your fishing poles, look no further! Designed here on Long Island, NY (surf fishing capital of the world) this mounting system provides a simple and elegant solution to a common problem. That problem... Where do you mount your fishing poles on the Bronco?
Utilizing the existing mounting points on the front of the truck our stainless steel bracket system provides a secure and stable system to support 1 or 2 rods (per side). Each holder is designed to safely and securely hold your fishing pole without damaging it. The built in angle of the mounting system allows you to transport long fishing rods without the fear of snagging an over-pass or electrical line. The rods sit at an angle hovering over the roof line.
Simply bolt on the system, slide in your fishing pole and head to your favorite fishing spot.
The single kit allows you to install the fishing rod holder on either the driver side or passenger side. You have the option to install the system on the outside or inside as well. Keep in mind that installation on the inside of the factory limb risers will prohibit the hood from opening with the system installed.
The double kit includes two (2) rod holders (along with 2 brackets) and installs on either the driver side or passenger side. The two rod holders mount back to back. This will prohibit the hood from opening with the system installed (you'll need to unbolt it if you need to open the hood). You may also opt to split the two holders and have 1 on the driver side and 1 on the passenger side as well. We've provided sufficient hardware in the kit if you want to separate the two.
FEATURES
  • .125" #304 Stainless Steel Bracket
  • Nylon/Acrylonitrile Butadiene Styrene Fishing Pole Holder
  • Powder Coated Black Finish
  • Designed & Manufactured in the USA
INCLUDES
  • 1 or 2 KR Off-Road Brackets
  • 1 or 2 Fishing Pole Holders
  • Mounting Hardware
  • Instructions
FITMENT
  • 2021+ Ford Bronco
WARRANTY
Lifetime Warranty for the original owner.
(Photos shown may differ slightly based on final product. The final product may be thicker stainless steel or aluminum).
Looks good I have the Bronco Raptor coming will it fit the Raptor the same
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Looks like a much better solution than this!
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) ED468D8A-697F-4923-9AE2-397B8ABF883E
DaBronco
Connor
Massachusetts
Ford Explorer
"You're going to need a bigger Bronco"- Martin Brody 2022
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 20220508_165529
I guess this lighter rod will have to do for now...
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 20220508_165556
As they say: "It's not about the size of the rod, but the motion of the cast".
All jokes aside can't wait to get my Bronco with a blend date of May 10th (only a 657 day wait), so late May early June arrival just in time for Striper Season and will for sure be rocking these up and down the South Shore.
Joey.calc
Joey
Barre
2016 VW GTI
Here you go. Some exterior holders will make transport of my entire setup easier!
Ford Bronco GIVEAWAY | KR Off-Road Fishing Rod Holder (ENDED) 8F62AA7C-59A0-4609-A421-E3170C19613C
Joey.calc
Joey
Barre
2016 VW GTI
I used to do this in the holsters we have on the boat with small bungee chords. Should work fine for these as well 👍🏼
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
What will these retail for?? I don't have my bronco yet so I do not qualify.
