DETT
DETT
They make that truck which is pretty high, look really low.
Agreed. Resembles an OBX now (no offense OBX owners). It was the best solution I could come up with between functionality and cost.
96GreenBronco
Andrew
Fl
1996 Ford Bronco XLT, 2021 Ford Bronco Badlands 7M
Looks great! Any idea if you would need to remove the factory rock rails for install? I have a Badlands coming someday...
DETT
DETT
I haven't seen how the factory rockers are installed but I assume they use the same threaded inserts in the body panels. Even if they don't, there will undoubtedly be interference between the two.
dweskamp
Dan
Missouri
2016 GMC truck
I was encouraged to share some photos of the Go Rhino Dominator Extreme D1 steps I recently installed on my 4dr Wildtrak.
Initial thoughts are mostly good. I do have some critical feedback though.
First thing first, install sucks! Get yourself some help and a lot of patience (or adequate amounts of your favorite beer). I did it myself and I'm no grease monkey so it can be done. I suggest searching YouTube for install videos that go over different methods that may work better for you.
I also think the design of the mounting brackets need to be tweaked just a hair. The steps are sloped down and away from the body. They function fine enough but they look saggy and in winter weather I'm afraid they might be a liability.
It should be an easy fix for the manufacturer, just add 4-5 degrees to the top mounting surface to correct for the "sag". The DIY fix will involve some sort of shims between the body and brackets. Probably an 1/8" will do, maybe 3/16".
And some pictures for those of you who are going to ask about Clarence... I used the leveling feature in my phone app to take these to get the best angles I could manage. It appears that they take about 5" away from the bottom of the pinch welds.
These do a great job of keeping rocks and debris off of the rockers and doors. And for basically the same price as OEM mudflaps they provide functionality for my family.
Those Goodyears are rock grabbers and throwers. Nitto Recon first mod
BandofEskimoBrothers
Jay
Fort Mill, SC
It looks like these completely cover up the pinch weld. Is that true or is it the covering you used on the rocker that is doing that?
DETT
DETT
DETT
DETT
AZshot
Desert Southwest
Vintage Motorcycles, F-150, various other
I'm looking at either the DSS or the D6, because those two don't seem to have the step down as the one you picked. Maybe keep a tad more ground clearance. I can't tell the difference in the two yet....
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
I'll be interested in hearing your thoughts on the Nitto Recons. I've been eyeballing them. Why those over the Nitto Ridges? Thanks.
acnp2022
CT
ford
I installed a different GoRhino step which doesn't drop low. They are subtle and nice
Ford Bronco Go Rhino Dominator Extreme D1 Sidesteps Installed on 4-Door Wildtrak 11
ICUGAZN
Kevin
2019 Raptor
Can you provide a link to this one? Is this one a slider as well?
acnp2022
CT
ford
