- Jared
- Jul 14, 2020
- 210
- 1,258
- 1,860
- South Florida
- Website
- www.lethalperformance.com
- 2020 First Edtion 2.7L / 2020 Shelby GT500 CF
- Raptor
Hey All,
For those looking for a variety of choices and options of different styles of running boards and side steps, we have just the thing.
With 6 Different Series of different designs, Go Rhino is the Go to option when looking for steps and other accessories for your truck or SUV. For over 30 years, they produced thousands of products for various vehicles, and now, they have the full line up for 2021+ Ford Bronco ready for anything!
Dominator Extreme Series
Dominator Extreme D1 D14129T
Check them out here!
Go Rhino Dominator Extreme D1 SideSteps - Complete Kit: SideStep + Brackets (Bronco) - D14129T
Dominator Xtreme D6 D64129T
Go Rhino Dominator Extreme D6 SideSteps - Complete Kit: SideStep + Brackets (Bronco) - D64129T
Dominator D2 D24129T
Check them out below!
Go Rhino Dominator Extreme D2 SideSteps - Complete Kit: SideStep + Brackets (Bronco) - D24129T
Check the entire Dominator Line Up here below!
https://www.lethalperformance.com/s...ng/side-rails-and-steps?manufacturer=2282&p=1
OE Xtreme Side Steps (4” and 5” Bars)
4” Stainless: Go Rhino 4" OE Xtreme - Complete kit: Sidesteps + Brackets (Bronco) - 684412971PS
4” Black : Go Rhino 4" OE Xtreme - Complete kit: Sidesteps + Brackets (Bronco) - 684412971T
5” Low Profile Stainless : Go Rhino 5" OE Xtreme Low Profile - Complete kit: Sidesteps + Brackets (Bronco) - 685412971PS
5” Low Profile Black : Go Rhino 5" OE Xtreme Low Profile - Complete kit: Sidesteps + Brackets (Bronco) - 685412971T
V Series V3 Running Boards
The V Series V3, 5 Inch Wide Oval, Side Steps combine corrosion-resistant textured black powder coated aluminum boards with anti-slip tread-patterned poly step pads.
Check out the entire Go Rhino lineup here at Lethal Performance below!
https://www.lethalperformance.com/s...ng/side-rails-and-steps?manufacturer=2282&p=2
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
- Drop Steps
- No drilling required
- Protects OEM rocker panel
- Full length with outer rub rail
- Great for high clearance use when step area is still needed
- Wide running board/rock slider style board.
- Punched steel step plate area has raised hex pattern to provide no-slip grip.
- Has option matching bolt-on 4” Drop steps.
- Provides Sturdy Step Area for Vehicle Access
- Great for Accessing Vehicles with Lift Kits and Oversize Tires
- Easy Installation-No Drilling Required
- Uses OEM Step and Rock Rail Mount Locations
- Steel Step Pad is Removable
- 71" Long
- Polished stainless steel finish
- Bolt-on, no-drill installation for most applications
- With welded-in and polished stainless steel end caps
- OE Xtreme brackets compatible with 4"and 5" bars are included
- SuperGrip step pads allow easier, safer entry and exit
- Internally fortified extruded aluminum core supports up to 300 lbs per step pad-600 lbs total per side
- Industry-leading 5-year limited warranty
- No drilling required, Bolt-On Installation.
