Going for factory Roof Rack & Rails for 2-door Bronco? Or go aftermarket?
Gpscharron
Claude
Waynesville, NC
2021 FORD Bronco, RV- Ford E450 (Thor Vegas 24.1)
I have a newbie question and I am seeking advice as well. I am wondering if I should purchase the Roof/Rails for my 2-door bronco or should i wait for aftermarket. Will it get in the way of me taking off the roof panels? Will it obstruct me view?
Does anyone have any pictures or recommendations?
Thanks for your consideration!
Claude
Member 1145
Ruggles
Lindsay
NH
1999 XJ Cherokee
I am wondering the same thing! The interactive garage builder site shows Yakima bars mounted on just the rear portion of the roof. I think the factory roof rack looks a little clunky and would prefer the smaller Yakima bars just on the back but I don't know if it's actually going to be a real thing or not. I have an older Yakima basketcase cargo rack I'd like to mount up there.
BigAl
Al
2006 Honda Pilot
I think the difference is the factory rack allows you to remove the front portion of the roof with the rack on while the normal style yakima rack will require all the roof panels to remain in place.
rapidredbronco2021
Jack
Westchester, New York
2021 Bronco Badlands 2 door MT
Idk for me depending on the price I might just get the one from Ford. Stuff like a roof rack might be one of the first accessory I add to my Bronco. I'm hoping to see a catalog of some sort of all the 200+ accessing when we get to build our Broncos
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Ford Bronco Going for factory Roof Rack & Rails for 2-door Bronco? Or go aftermarket? BroncoRack
This is the weirdest picture in the bronco gallery. Almost everything about it is weird or different from the other Bronco pictures.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Yeah. They took the doors off the hard way.
(I'm assuming this is a CG image created from whatever pictures they had on hand.)
Edprem
Porsche
Following. I would also like to know if the roof rack will not allow you to remove the roof. I plan to have mine off most of the time.
den_jkur
Deepu
2017 JKUR
What has me hesitant about the stock rack is the weight rating of 120lbs,hope they make something stronger as most Rooftop tents are close to that weight.
Yes, the Roofnest one I was looking at is around 160 lbs, will need a stronger rack.
Rick Astley
Up Doug's ass
d
Yakima is the official supplier for the roof racks Ford sells, as has been the case for a few years now.
The "factory" roof rack was designed and made by Yakima. I'll be picking up the "factory" roof rack as there will be plenty of accessories which go with it and it will fit the unusual mounting point arrangement that Bronco has. Even if it ends up being $600, that's still cheaper than an aftermarket rack which will have about the same load rating. If you want a higher rating, it will have to be clamping entirely onto the roll structure itself (as opposed to latching onto it) as there isn't a hard point up there like a flat bed truck would provide.
FWIW; from what i've seen (and have been paying attention to the roof-off photos specifically related to the roof rack), I believe that the clamping ends for the rear mount points will slide inward and connect to the boron bar structure or be mounted to them the entire time with an access panel through the roof. Could be 100% incorrect on this, but as nothing official has come out this is simply my speculation.
Ruggles
Lindsay
NH
1999 XJ Cherokee
I am hoping to have something like this, for my cargo basket on the back.
aplm7
Andy
Vacaville, CA
Explorer 2015
Ford Bronco Going for factory Roof Rack & Rails for 2-door Bronco? Or go aftermarket? Annotation 2020-08-27 181715
I really like something about this picture, might be the grill? The whole thing just looks more like a truck than a jeep. Is it a 4" lift shown?
Ruggles
Lindsay
NH
1999 XJ Cherokee
It's just the default Big Bend trim on interactive garage builder, I'm guessing the real one will not be so tall haha
lobbs611
Kyle
Independence, MO
2D JL Rubicon
Yeah, I'm going to have to see some additional capacity out of the stock set to go that route. Whether it's a way to directly anchor them to the cage or an aftermarket solution that still utilizes them.
Desert_6G
Phoenix, AZ
Ranger
I will go factory. It's only $400
