Going to swap Sasquatch wheels with Base steel wheels
  • Thread starter Deleted member 18388
  • Start date
  • Watchers 5
Guest
I'm ordering a base sasquatch. However I like the base steel wheels better. Anybody know the dimensions of the sasquatch wheel? I'm going to buy steelies to swap out with it. Also would appreciate if people had a good place to find some steelies?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Here are all the wheel specs.
Ford Bronco Going to swap Sasquatch wheels with Base steel wheels 1617069006047
The steel wheels are carried over from the Ranger.
The 17x7.5 is the black steel wheel. That’s a pretty narrow tire for a 315 series tire... but it’s better than the 7” on the silver 16” steelies.... though offset is still wrong.
Guest
Thanks a bunch. Wonder if I'm the only one that actually would rather have the steelies than any other wheel.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I really like the black steelies, and am considering swapping out for them on my Badlands (non-Sas).
There’s handful of us on the board, and we normally catch flack when we make ourselves known... but we exist.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I think you'll find plenty of company on this forum. The sasquatch wheels are a little busy for my tastes so I'm on the hunt myself.
Guest
Agreed. My only concern is finding steel wheels to fit the sasquatch tires. I dont want to have to spend $1300 on tires to match the steelies.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Offset is really going to be the issue. The stock Bronco/Ranger offset is +55, which we’ve deduced is good up to a 285. If you go any wider than that the tire will interfere with the upper control arm.
Sas wheels are +30 for the offset (plus the wider flares) which obviously works for the 315.
I choose not to ever deal with wheel spacers (plus they’re illegal in my state), but that’s obviously the fastest way to deal with that issue.
There’s a bunch of 0 offset wheels out there, but that sticks the tires out an additional 1”+ beyond Sasquatch (maybe almost 2? I can’t remember now).
This obviously brings with it a whole host of new problems.
I’m expecting we’ll shortly see a whole bunch of +30 aftermarket wheels to take advantage of the Bronco crowd.
HoosierDaddy
Indiana
You MIGHT find steelies to fit the Squatch tires. The biggest issue is the width of the tire. You'll really need the +30mm (or less offset) to get the tire away from the suspension parts.
Here's a few actually.
I can't speak to the quality of these. I'd do some research. I once had a set of wheels that were bored off center. Vibrated so bad, made your vision blur at highway speeds. lol
EDIT: The three load range C 315/70-17 tires I found on line all work on an 8" thru 11" wheel.
Guest
So let's say I found 35in tires that would fit the base steelies. Would those interfere with any suspension conponents?
