Got my vin# but there’s a problem
Thomas1984
Thomas
St.johns Newfoundland Canada
Dodge Viper
I received my vin and I can’t get the ko2’s with the badlands optional wheels anyone else having this issue? I ordered the optional wheels with the M/T back in January but a month ago contacted my salesman to change to the A/T’s now I have my vin # and now it says I have the standard wheels and A/T’s.
DeltaBravo
Delta
MIKES MOM
I received my vin and I can’t get the ko2’s with the badlands optional wheels anyone else having this issue? I’m beyond mad
i thought once a vin was generated we couldn’t make any other changes
SnowBronco
Canada
Aren't the bfg's the standard tire with the upgraded wheels? The Goodyears are the tire upgrade.
martyb
Marty
Winneconne, WI
GMC Sierra Denali, VW Atlas
What DB said.... I got the KO’s on my DORA with the optional Badlands wheels, so it can be done. Of course I’m not special enough to get my first day res pulled yet so I got that going for me.
Thomas1984
Thomas1984
Thomas
Dodge Viper
Salesman is saying they get kicked off when they try to add it, This is crazy I’m beyond mad
Thomas1984
Thomas1984
Thomas
Dodge Viper
I wonder did the dealer select it wrong when I told them to change my tires to the ko2’s? And now it can’t be changed?
SnowBronco
Canada
You shouldn't have to add anything. They are the tire. Only upgradeable tire is Goodyear. Ask him which tires the thing is coming with then. Obviously something lost in communication...
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
They are full of shit. They had a problem figuring it out at my dealer too, but eventually figured it out: (I think the code was 64W.)
Ford Bronco Got my vin# but there’s a problem ORDER Summary
SnowBronco
Canada
Sorry I thought you just meant the tires. If you're have your vin and trying to add the optional wheels now, then no. You cannot make changes. You should have made that change in the 9 months you had to decide before the April 9 deadline. I tried to change my color last week to. Got bounced back. Found out it was because I had my vin and my order was locked.
martyb
Marty
Winneconne, WI
IIRC, someone else had the same problem and it turned out the salesman was trying to add the Sasquatch wheel instead of the upgrade wheel
ColoradoGuy
Correct, if you've been assigned a VIN you can't make any changes. Sounds like you are getting the standard wheels with BFG K02s.
Dads_bronze_bronco
Yeah - I think that was the problem at my dealer - or maybe it was the optional Black Diamond wheel, but they eventually figured out how to add the Optional Badlands wheels by themselves.
Erock
US
2018 F150 Alpine edition
At least you have a vin#... you could be on the list of folks waiting another year... 🙂
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Optional wheels with the standard KO2s were added no problem to my order.
If you asked for the change after your VIN was assigned, you’re out of luck.
If you asked for the change before the VIN was assigned, you’re still out of luck but you should negotiate how the salesman will make it up to you for being uninformed and not configuring it the way you asked for.
Ford Bronco Got my vin# but there’s a problem 697DEDF4-BAC9-414D-955C-E8DC0896D10B
Ford Bronco Got my vin# but there’s a problem 1618676786931
