Gremlin / Reported Issues Thread
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Has anyone started a thread that consolidates all known issues currently with the bronco? Far as I'm aware, hardtop scaling/delam... Soft top rubbing, and an engine seizure. Anything else?
I guess i'll keep a running list for those who want a one stop shop. All info i'll gather on the site and post links to those threads. I will keep the issues logged by engine/trim to see if there is any consistencies. If something is wrong or I missed something post it.
Big Bend/ Outer Banks grill causing whistle: Fix on the way.
2.7 Engine seizure: warranty replacement
2.7 During GOAT mode test TCS warning lights came on: **need update**
2.3/2.7 Hardtop scaling: Assumed old tops will be free replaced
2.3/2.7 Soft top rubbing paint of bar: **Need update**
2.3/2.7 Soft top wearing out when opened/closed: **need update**
https://www.bronco6g.com/forum/thre...hrough-after-4-weeks.20660/page-2#post-738665
MontyMoose
Monty
West Olive, Michigan
2016 Road Glide, 2018 F-150, 2021 Bronco
Mirror and/or grille whistle
Broncolli
MD
'21 Back Diamond 4 door MIC
1. Hill Assist error
2. 4x4 error service soon
3. Popping noise/hardtop latches
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
Add torque converter clutch solenoid performance code to the list.
David196
Pennsylvanian
Chevy Traverse
I keep hearing more complaints, problems and issues.
Windshields breaking/cracking
Windows constantly need reprogramming
Windows rattle.
Soft top rain flows into your lap
Soft top breaking tabs on windows
Hard top issues 1.0 and 2.0
Tow truck story. Less than 1000 miles and the engines stopped while driving. (Not worth the risk) Some valves, some computer/sensors stuff. Does it matter? Driving and your engine shutting down is not a good thing. Family safety is vital and this vehicle has a shitty record so far.
Hoses and bolts issues
Coolant leaks.
Paint issues, scraps and lack of paint.
Random codes being thrown.
I always liked Ford products, i really wanted one last manual transmission vehicle, before they go extinct. I think purchasing this will not be beneficial to my family.(Bronco should be in this week too)
I'm thinking the best thing to do at this point to is to pass on this vehicle.
Wait for it to get more reliable IN A FEW YEARS.
Purchasing this now will most likely be a headache later on.
1941
Emil
New Orleans, LA
2020 Jeep Wrangler
I know first year models can often have issues, but there seem to be SO MANY of them with the Bronco. I hope they can get all of it sorted.
I also know there are probably tons of folks who have their Bronco and have no issues at all, so I know Ford is capable of building them reliably, they just need to do it consistently.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Here is my list of discussion/check items:
Ford Pass Rewards Points:
200,000 for MOD to MIC roof
11,000 User Appreciation Points
20,000 Early Reservation Holder
42,000 New Vehicle Purchase
1,100 converting before March 19th
Customer Satisfaction Funds: $1,000. Have your dealer go to the FDAD CLAIM PAGE on the Dealers Bronco Dashboard, if they dont know about it.
Items to check (based on Bronco6g OP feedback):
Pulley rub/ proximity next to radiator hose
Coolant hose clamp tight
Battery terminals tight (negative loose)
MIC Hardtop rough/sharp edges, gaps, leaks, roof rattles latches...especially seal in middle
Test all roof latches (some missing)
Check seat stitching and ensure seats match
Check seatbelt webbing for defects
Interior and trunk lights/bulbs work
Roll all windows up at once
Check window auto-drop
No license plate mounting (if mounting alternate location)
Owners Manual and Tool kit in glovebox
Tailgate hinge area has paint issues
Any TSBs/ Service Alerts?
Paint bubbles/paint defects
Missing paint in door jambs/door brackets
Body panel alignment
Whistling mirrors
Sound deadening installed
Check underneath for corrosion
Check for transport damage
Check for rail dust (small specs of rust that will corrode). Must be clay barred off and repainted, or try iron/rust remover
Fluids all full (oil, washer, brake)
Confirm SEVEN Quarts of oil filled, not six. Ref:
https:///forum/threads/bronco-team-engineering-confirms-7-0-quarts-for-2-7l-engine-oil-change-is-correct.29047/
Full tank of gas (we paid for it!)
Door bags
Strut on back window unglued from hardtop (why not drilled in??)
Check all three bolts in the fuse box for looseness
Turned the above into a Google Doc...updated frequently:
https://docs.google.com/document/d/1bCKnGypjpN2g2Qz8UtEC1-eqGUeqm5g9fj0tdrady3E/edit?usp=sharing
JohnnyBronco
Pennsylania
X4
Door bags? Yeah, once I thought it was part of a package but now think the package included roof bags and no such bags for soft top.
But some glitches to add:
Key not recognized when it is truly in vehicle but vehicle still runs and drives
Snow or ice on Pre-collision assist sensor disables precolllision assist in icy-snowy conditions
Cannot remove fuel nozzle from flapper equipped fill pipe without losing a little fuel to atmosphere - gotta be an EPA issue
Cat
Cat
Whidbey Island, WA
Your key recognition item...our Subaru will still run and drive, once its started even when the key is not near it. The Bronco won't start without the key near it, right?
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
I've been looking for something like this. A checklist for all of us to look for when we take delivery.
Raskew
Rick
Vancouver, BC
1970 Bronco, 2018 Stinger
A few things to add from a previous list on here;
Windshield cracks/chips
Chips in top of door glass
Scratches in dash, console, and other plastic areas
Tire pressure (I've heard some tires have been left over inflated)
Ig_bronco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I appreciate the additions I need to edit the original post. Before I do can you supply or add detail to these? Especially the chips ultimately links to the posts would be preferred
Raskew
Rick
Vancouver, BC
310BroncoTK
Southern California
GX470, Macan
I found this imperfection that I wanted to share so you all can check for this issue, too. On the inside of the door, passenger side, the rubber is not aligning with the plastic part (sorry don’t know the lingo). Dealer has ordered part and I need to schedule a repair once it comes in.
Also, I found what look to be QC stickers on the inside of the soft top, where it connects to the rear. I’m guessing this is why my rig was held up in QC, but not sure what it means. Anyone know what the issue may have been? Saw them when I went to remove the top. By the way, the soft top was surprisingly heavy to remove !
I initially posted this on the 10/25 group thread and thought I should re-post here. Anyone else have these issues?
