"Ground Clearance" measured from?
Instaurare
Southwest
2018 JLR
Ford claims a ground clearance of 11.5" for the Bronco with 35" tires, but does anyone know where this clearance is measured from on the truck?
AcesandEights
Ace!
Oregon
DR650
The cupholder. It's measured to the bottom of the cupholder.
Cousin Eddie
Jack
Pennsylvania
Cadillac
sko
Tomasz
Denver,co
elantra, have dep on a badlands
Rear axle?
Used2jeep
Massachuvian
2007 Crown Vic P71
The lowest point. Most likely the pumpkin or a shock mount.
BAUS67
redneck
Central PA
My guess is shock mount. (y) (y)
Used2jeep
Massachuvian
2007 Crown Vic P71
Used2jeep
Massachuvian
2007 Crown Vic P71
TJconvert2.7
New England
Listen I’m not Matt Damon in Good Will Hunting, but 11.5 with 35s, equals 8.5 for the Big Bend.
stock Subaru Forester is 8.7, with a very economical 2” lift, 10.7... less than an inch off a SAAAAAZZZZZQUAAAAAAATCCCCHHHH.
Tee hee...
Gamecock
Tee hee...
How would a 2” lift raise your Subaru ground clearance from the diff by 2”? I’d like to see that magic....maybe try 4” bigger diameter tires to get there homie, but a suspension lift on your Forester gets you nada in ground clearance from the low point. Lift that Forester though brah...go ahead.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
This horse got beat to death back in the summer when Ford released all the initial specs, but no, we don't know where they actually measured from. You can bet it wasn't the rear shock mount as they don't want numbers like that getting out.
Goat4454
Northern Ontario
Audi
Lots of research went into this. I’m sure there is a good reason why they settled on this ground clearance. Will it feel like driving so close to ground it could be a sedan. Haha. !
