Straight guesses:Cost---Upgrade/option to 2.7..,6cyl.?
Cost---Upgrade/Option to better sound system..,10 speakers?
Although upgrading an F150 from the 3.3L V6 and 8 speed Auto to the 2.7l Ecoboost with 10 Speed is only $995.Straight guesses:
Upgrade to 2.7L 10 Speed Auto from 2.3L 7 Speed Manual: $2495
Upgrade to 2.7L 10 Speed Auto from 2.3L 10 Speed Auto: $1995
Lux package (10 Speaker B&O+): $2495
Don't forget the cost for Mid and High in there which is all included in the Lux, to jump straight to the B&O, unless an ala carte option, would be closer to $7500 imo.Straight guesses:
Probably pretty accurate.Don't forget the cost for Mid and High in there which is all included in the Lux, to jump straight to the B&O, unless an ala carte option, would be closer to $7500 imo.
Is the 2.7 in a manual an option?
If you are at Outer Banks, that already has mid package. To get to Lux would likely be $4,000-4500.Don't forget the cost for Mid and High in there which is all included in the Lux, to jump straight to the B&O, unless an ala carte option, would be closer to $7500 imo.
Going off the price increase of the base from 2 door to the 4 door, switching to an automatic transmission from the manual should be about $2,200.Straight guesses:
Im ordering B Bend with 2.7 V6 , IF its not tpp much$Is the 2.7 in a manual an option?
It seems most of the bigger options are in the mid package, so I certainly hope Lux doesn't exceed $4500.If Lux on an Outer Banks is $4500 I’ll cry.
True but I know most manufacturers completely rip you off for the B&O speakers. Probably at least $1295 for that alone. Hopefully it will also be a stand-alone option because that’s really the only Lux item I care about.It seems most of the bigger options are in the mid package, so I certainly hope Lux doesn't exceed $4500.
