Big Sky Rack I use in my Wrangler. I modified it a bit to mount across the rollbar. I didn't even have to drill a hole already in the rollbar. I hope the Bronco will work out similar
Yep!Isn't that also listed in the accessories catalog? (Noth the one circled in yellow...)
Apparently this is an accessory, although it looks quite tall and possibly not long enough to butt up to the inside of the rear door when it's closed, although that would be silly if its came that close and did not.
I seen in the 200 acesories list there were a couple lock box options but no pics I live in a communist state so got to be careful transporting to range magazines have to be separate from fire arm and ammo has to be separate I shoot sporting clays and am getting a 2 door was told my beretta should fit in the back without having to put my back seat down this made me happyI have been thinking about this as well. Being as all broncos will have a removable top, or a soft top, weather and security will be issues.
I've been thinking about some sort of sealed tube, case, or drawer that is either protected by itself, or that will reside in the cargo area protection that I will probably add. Too many variables to even consider before I finally have the MY22 in the garage.
When I momentarily forget the weather & security concerns, though, I really like the angled rollbars in the rear for likely locations.
My planning will revolve around the space under the backseat of my four door Bronco when I get it. My primary hunting is pheasants here in Iowa, the space below the rear seats looks like the perfect place to put a slide in / scabbard gun case for my gun storage during hunts. Once I get the Bronco delivered I will work on a pheasant hunting season layout complete with dog box, and supply box pretty swiftly.Bump
I’m using mine for hunting and need to store two long rifles. I was thinking about getting two scabbards and bungee strapping them to the corners of the frame in the rear. Barrels would be pointing towards the windshield. Wonder if they can make a bracket or strap that can wrap around the frame by the roof to support instead of bungee cord. My bow would just lay in the case in the back.
Planning around a 2 door.
I believe you’d just slide the drawer out and you could access the under-floor storage/jack.
I like this idea but trick is to get to the compartment under the floor for jack etc.
I'm planning on something utilizing the MOLLE seat backs sometime in 2075 when I get my Black Diamond.Bump
Ok yeah gun storage is cool and all but what kind of dog?My planning will revolve around the space under the backseat of my four door Bronco when I get it. My primary hunting is pheasants here in Iowa, the space below the rear seats looks like the perfect place to put a slide in / scabbard gun case for my gun storage during hunts. Once I get the Bronco delivered I will work on a pheasant hunting season layout complete with dog box, and supply box pretty swiftly.
Interesting. How would you use the MOLLE?
Yellow Lab, named Kepa. Just turned 2, she has just completed 3 of 4 health certs. Hips Excellent, Elbows Normal, Embark genetic testing all clear. One test left as she has an Ophthalmologist eye check set up for the first week in August. I am bias as heck but she's a very good in the field being so young. She stays close and follows commands in the field very well.I
Ok yeah gum storage is cool and all but what kind of dog?
Gorgeous dog! I've got an 8 month old GSP I'm training right now because I guess I hate myself?Yellow Lab, named Kepa. Just turned 2, she has just completed 3 of 4 health certs. Hips Excellent, Elbows Normal, Embark genetic testing all clear. One test left as she has an Ophthalmologist eye check set up for the first week in August. I am bias as heck but she's a very good in the field being so young. She stays close and follows commands in the field very well.
Over the spare tire, of course!I'm still trying to figure out where I'm going to tie down my deer.
