Gun Racks & Storage [*** Storage Talk Only *** No Glorification, States, Laws, Permits, Politics or Usage Discussions]
Midlife Crisis
August
Missing my 86 Bronco
A Safariland holster with a molle adapter plate would be a great solution. Their molle adapter plate could probably work with many other holsters that accept some type of screw in the belt clip area
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Anyone found the perfect location for a magnet mount?
These are not magnetic mounts, but options I’ve seen so far are:
- Center console, either side w/ Mountains2Metal MOLLE panels (drivers side requires drilling at this time)
- Driver door pocket w/ Mountains2Metal MOLLE panel
- Velox Offroad gullwing rear window panels with a MOLLE panel attached to C pillar
just throwing this info out there; I’m curious on this as well
JimmyG
Greg
Fords and Cadillacs
broadicustomworks
Hanging Rock, North Carolina
Down low, to the right of the steering wheel, as low as I could get it and as close to the center stack as I could get it.
And it still hits my leg.
So no, I do not recommend.
I think the molle M2M center console setup is the best so far.
m1chaelmoore
Tennessee
Ford f250
Yeah i thought about the front door pockets. they look nice anyway and although i have only had it 2 days i think the nets are worthless.
CKXVII
CK
F-150
I’ve had the M2M molle panels for about 10 months and while drilling into plastic trim sucks, it’s held up well…you just have to be careful when running straps through the grid.
For the times I want my pistol readily accessible, I use the Vaultek Single Slot Pistol Rack. It has a really strong magnet & grooves to grip the molle panel. Effortless install/removal & keeps the firearm upright / ready to draw.
RC Bronco
Rob
Kansas
Ford Bronco Gun Racks & Storage [*** Storage Talk Only *** No Glorification, States, Laws, Permits, Politics or Usage Discussions] 833B172D-0AF2-413A-9A24-1D0CD562C054
Thanks for the info here! Do you have any issues with the Vaultek rubbing against your leg?
broadicustomworks
OK I'm sold. Sweet setup!
CKXVII
CK
F-150
No issues. No rubbing. If I make contact w/ it, it’s a smooth surface so it’s not like it’s going to result in any uncomfortable experience. Plus, you can just move it around on the molle panel to fit your preference. You can even angle it to give you a better draw. It was designed to sit on the molle panel of a Vaultek safe door, so it does a great job of staying in place.
dahandel
Dylan
Currently use this I like it. My holster can contect to the moly or I put the pistol inside like the picture advertises
bradcd
Brad
Indiana
Saab 9-3
I purchased some rubber coated magnets on Amazon. Knine Outdoors was the brand. There are various magnets like that with a center screw hole or side holes, or you could Gorilla tape it somewhere.
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
I don’t like the idea of a magnet mount in the vehicle. I have an extra QLS mount on order and can report back when that finally comes in. I also like that idea of the Vaultek Single Slot Pistol Rack, it that would see best for road-trips and not necessarily off-roading.
Bronco1971
Bob
Lots
Off road I actually wear my holster on the non-console side depending on the seat I'm in. I have a Fobus adjustible paddle holster that is actually comfortable after I trimmed the bottom of the paddle a bit. I just adjust it so the handle is facing up while I'm sitting.
I prefer to have the gun on me while off roading because there's always a lot of in and out and an encounter with a snake or what not may happen.
