Tricky Dick
Dick
PNW
www.TD-Distributing.com
That’s bad ass. Can’t wait to see it all done. Brace yourself for all the people that are about to lose it that you chopped up a first edition lol.
1 of 940 no less! But now it's a 1 of 1 and I'm loving it.
Toccoa
Isuzu Rodeo Sport
Almost done so I thought I'd start a thread.
Chopped up a bronco more-doors top and did some fab work. Got a few adjustments to make and a final sand and paint, but overall I'm satisfied so far.
The front two top panels still lock in place to the new half-cab the same way, and they are obviously still removable.
The Bronco top is nearly 3 ” narrower in the rear than at the B pillar,.so this presents a bit of an issue. Some massage is needed to make up for the wider B-pillar and get the rear of the old top to match up well with the middle of the truck.
I made sure I can still use my old MIC 2 top ... and I will add 4130
inserts to the roll bar at each end that can be bolted in with aircraft grade fasteners. The roll bar will be removable.
The original hard top is still usable and now I have two top options.
I will build a bolt-on bulkhead across the front of the bed that will match up with the bottom of the window. The window is the same, so the defrost, wiper and washer will all be functional.
The side curtain airbags did need removed, and I plan on installing a set from a 2dr F150 in the near future, as they appear to be installed in the same area and fashion.
I also ordered a new back roll bar cross support that I will build into a removable cross support while the half cab is installed.
Still have lots to do.
Bulkhead
Speaker pod mounts.
Tail gate
Tool boxes built into bed.
Here's a few pics of my progress. It's a bit dusty as I'm still sanding here and there.
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 1649392980535
Toccoa
Isuzu Rodeo Sport
broadicustomworks
Hanging Rock, North Carolina
YES! Rock on, @BigMeatsBronco
Good job, bud. Looks killer so far, can't wait for the final product.
EDIT:
Just because I can. And Foo fighters.
mjohnso3
Marc
Atlanta
FJ Cruiser
Looks awesome this brings back memories of my very first Bronco I owned that actually I learned to drive on, 69 half cab. The handful of renderings I saw where nothing more than just extended bed pickup truck Broncos. You went full retro and kept the original look and how they were offered from 66 to 73 I think or 72.
InTheShift
Shift
Overland Park, KS
4dr Base w/Sas
Awesome job!
flip
Phil
IN
www.ruxerparts.com
Fords
A bolt-in bulkhead that will divide the cabin from the bed. It will be watertight.
Are you fabing this from scratch or going to use something like a donor from a bed box front panel?
