mikey_photo
Allentown, PA
2021 2dr Badlands
Almost done so I thought I'd start a thread.
Chopped up a bronco more-doors top and did some fab work. Got a few adjustments to make and a final sand and paint, but overall I'm satisfied so far.
The front two top panels still lock in place to the new half-cab the same way, and they are obviously still removable.
The Bronco top is nearly 3 ” narrower in the rear than at the B pillar,.so this presents a bit of an issue. Some massage is needed to make up for the wider B-pillar and get the rear of the old top to match up well with the middle of the truck.
I made sure I can still use my old MIC 2 top ... and I will add 4130
inserts to the roll bar at each end that can be bolted in with aircraft grade fasteners. The roll bar will be removable.
The original hard top is still usable and now I have two top options.
I will build a bolt-on bulkhead across the front of the bed that will match up with the bottom of the window. The window is the same, so the defrost, wiper and washer will all be functional.
The side curtain airbags did need removed, and I plan on installing a set from a 2dr F150 in the near future, as they appear to be installed in the same area and fashion.
I also ordered a new back roll bar cross support that I will build into a removable cross support while the half cab is installed.
Still have lots to do.
Bulkhead
Speaker pod mounts.
Tail gate
Tool boxes built into bed.
Here's a few pics of my progress. It's a bit dusty as I'm still sanding here and there.
Wow this is really awesome… great job!
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
Did you need the room in back for your balls?
I love this, keep up the good work!
bhb
N NJ
Looks great. following.
BigDaddySquatch
Tony
Madison, AL
2012 Toyota Tacoma TRD Sport
Broncos_south posted your picture on instagram this morning. Just thought you’d like to know
ebrs929
Erin
2022 Bronco, 2009 F150
This is incredible. Great work!!!
RedHotLava
Red
DC
2005 Nissan Xterra
Bulkhead
Speaker pod mounts.
Tail gate
Super sick dude! I was curious if anyone else was going to do it after the BDS build, awesome!
gryphon1231
dj
Miami FL
na
Bulkhead
Speaker pod mounts.
Tail gate
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 IMG_1850
nice!
drive21bronco
North East USA
2021 Bronco Black Diamond
Wow Bold. Can’t wait to see it done.
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
my wife would kill me,but good on you man!
TimBee
Tim
Massachusetts
2019 Raptor
Totally diggin it! Looks awesome!
