Bronco Bob
Bay Area Ca
1977 Bronco, 1994 Bronco, 2009 F150, 2017 F 250
Bronco Bob
Bay Area Ca
I built a template out of aluminum to test fit. I'll use this bulkhead as for a week or so while I gather up some materials to build the finished one.
Also, I can add or subtract ideas (like a shelf or gun rack inside mounted on the bulkhead) and mock up the fit and look before I build the real one.
I'm happy so far with how it's fitting up.
Any suggestions?
Cross break the metal You’re using for the Bulkhead.
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Great project! Keep at it.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Got an little more done on the U-14 conversion... made some adjustments and primered it. Finished up the wiring and now the rear wiper/washer/defrost works! Still have some final sanding and buffing before it's ready for paint.
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 20220419_171902
I love and hate it. Hope to run into it in person one day.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Still working on doing the "little things" like mounted the rear speaker pods and moved/added a new dome light from the rear into my new top.
I moved my GPS antenna to outside the top, instead of inside on the roll bar. Reception cuts out far less now in hilly terrain or heavier timbered are roads.
Matched paint arrived yesterday so I'll try that in a few days and see if I like the color matched top...
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Yep you seen the real deal, no imposter!
Allan,
What your doing is awesome, and looking great. Keep up the good job !!!
Anything I can help you with, PM me and I'll see what I can do. I can make a lot of goodies, depending on what you want...... ;)
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Well well well, we have another entry into the Bronco truck club.
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 279423419_10159733730873609_4235935021776352427_n
They made a beautiful Bronco look like a truck that belongs in an old Indiana Jones movie. And not in a good way.
