BroncoUnicorn
Ford Bronco Base 2dr Manual
The installation date for my ARB dual compressor (100% duty cycle) finally arrived for my 2021 "unicorn" bronco. I had a local shop (Asheville Vehicle Outfitters) do the installation. This is the same 2 door Bronco that had the rear seats deleted from an earlier thread of mine.
The compressor was installed to the underside of the body, centered and towards the rear:
Ford Bronco Hardmounted ARB dual compressor with quick connect port installed 2021 Bronco Hardmounted ARB dual air compressor with quick connect port installed
It was mounted by drilling holes up through the body and bolting everything in, underneath the rear factory carpet.
The output air line was run to a quick disconnect port on the rear bumper using braided tubing, and comes out on the drivers side above the license plate:
Ford Bronco Hardmounted ARB dual compressor with quick connect port installed 2021 Bronco Hardmounted ARB dual air compressor with quick connect port installed 1
So when you need to air up you can just plug in the hose:
And turn on aux switch 1:
Ford Bronco Hardmounted ARB dual compressor with quick connect port installed 9C3C1AE2-8E0D-4A3A-A9C7-3760E501DC7B
Eventually I will be upgrading the front and rear bumpers with steel versions, but that will have to wait until later. I also plan to buy or make one of the 4-way inflater hoses so I can air up all tires to the same PSI at the same time. This is a 100% duty cycle compressor, so no worries about overheating or cool down cycles on larger tire sizes.
Tech Tim
Tim
Wet Side of WA
Jeep JKU
BroncoUnicorn
BroncoUnicorn
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
That is slick!
BroncoUnicorn
BroncoUnicorn
Did you consider mounting it in the engine bay?
I did, but I didn't like any of the possible engine mount locations. The engine bay is pretty messy and the dual compressor is a bit fat. There was unused space here under the body, and it's closer to the rear where I wanted the quick connect port. Time will tell if this was a good location or not..
Designkid
Kris
New Jersey
2021 Bronco Badlands
Clean install. Any particular reasoning behind using the only 30amp switch available to activate it when it, in all intents and purposes, is only firing a relay?
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
My wife is going to kill me now.
Rick Astley
Up Doug's ass
d
Get the ARB remote air kit for that and get those air filters moved into a safe dry place.
https://www.northridge4x4.com/part/...essories/171319-arb-air-filter-relocation-kit
Curious what you've seen from your own crew and also customers in terms of compressor life on these ARB units when they are mounted in locations which will see being fully submerged, lots of water, mud and impacts?
I've got the ARB twin on my short list but intend an engine-bay mount with aerospace grade quick disconnects on the terminals so that for daily driving I don't subject the compressor to constant heat cycles.
Or are these units so bulletproof that you're getting 5-10 years hard life out of them without issue?
BroncoUnicorn
BroncoUnicorn
My understanding of the install is that the aux switch triggers the relay on the compressor side, and the power is pulled from the battery directly:
Ford Bronco Hardmounted ARB dual compressor with quick connect port installed 0586CBB3-17A2-4F30-BC0B-5701B72D9E16
There seem to be two fuses. I assume that is one per compressor:
Ford Bronco Hardmounted ARB dual compressor with quick connect port installed 28494F82-381F-4315-9E2B-248B642E6A62
I was told by the installers that Ford doesn't map a specific wire harness wire to a specific switch, but they deadend everything to a single location in the engine bay so you can connect to the switch of your choice.
I assume that is what this is:
Ford Bronco Hardmounted ARB dual compressor with quick connect port installed BA81593F-2260-4213-8DD5-47309FA22A28
