Hazard lights/turn signal flash when auto start/stop or turning off Bronco and...
NE26
Robert
MA
BMW M4
Less than 150 miles on an Outer Banks, 2.7, Lux, SAS....
Sometimes, when the auto start/stop activates, the hazards will flash really fast, sometimes just the noise of the signals flashing but don't catch the signal flash on the dash. Has also happened several times when shutting the car off. Tonight it just flashed the right turn signal when I shut off the vehicle. Intermittent, but does some combo of the above everytime I've driven the Bronco.
Also, after leaving SiriusXM on a station for extended time, if you turn the tune knob it goes back to station one (or 998), not the next in line.
Last, normal operating temps for the engine? The digital gauge is new to me, so use to seeing the gauge sit in the middle (except the M4, always low). But just glancing at the digital gauge it seems to be creeping towards the high side, yet temp was reading 215 on a 60 degree night driving 30 in town.
Theherofails
Thomas
Phoenix
Someone had a water hose pop off because the clamp was incorrectly installed at the factory.. saw the post a day or two ago. I would start there.
TRMFAM
Rob
OK
I would take that in to the dealer...my bet is a ground issue somewhere causing the odd light issues.
Check the owners manual for the operating temps...as you now BMW's run much hotter than that...
zgoods
Zgoods
MI
Bronco Sport Badlands
Nokosh
Ohio
2021 Ford Bronco Outer Banks
I just got my two-door Outer Banks last week. I've noticed the same issue with the auto start and flashers whenever I stop at a stoplight. It's only happened twice though (out of probably 30 stops), so it's hard to take it to the dealership for them to figure out what's wrong.
Drex
Jake
215 (F) is not a normal temp for coolant in today's cars, but not outrageous if under a load or running hard in hot conditions, it is, however, in line with oil temps. Are you sure what gauge you are watching? Might it be oil temp?
The reason you are used to seeing gauges in the middle for engine temps is that they are not real gauges. They are 'set' to run in the middle if your engine temp is say...above 120F and below 210F, if the go above or below, they will peg at either high or low on the gauge. Watch the gauge next time, might take 5-10 miles for it to stabilize temps and they should move slightly up and down after that, depending on speed/airflow over the radiator. If they are rock steady, they are just fancy idiot lights and not real gauges.
4XMORE
AJ
OC
Ford Raptor
Did the dealer find a solution for you? Mine recently started doing this as well.
Toaster
Mars
‘18 JLUR, ‘19 Raptor
Any of you figure out what’s causing the hazards to flash? Just noticed mines been doing it too.
mrnoodley
Toms River, NJ
2012 JK, 2018 JL, 2020 Gladiator, 2021 2dr Badland
I have the same hazard flashing issue. It's completely random..
It's an odd issue, but at least I'm not the only one.
VBBADLANDS
Patrick
Virginia Beach, VA
2021 Bronco Badlands
Any updates? Mine just started doing this 2,000 miles in.
KStAv8r
N
Fiat 500 Abarth
Noticed my hazards flashing with random Auto-Stop/Starts.
Also randomly flashed when outside the Bronco as well; not the normal approach flash.
Morganstein
2021 Ford Bronco Badlands
Mine also does the random hazard flash - Badlands/High/2.3/Manual/4dr. I don't find it concerning but it is curious.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
Ugh, 7 months of people with this issue but no fixes. Anyone else find a fix for this?
KompressorV12
Portland, Oregon
