Height of 4-door Badlands with 33" tires, MIC top?
LetRBuck
Aurora, CO
C7 Corvette, Toyota Highlander
Anyone know the height of a 4-door Badlands with 33" tires, MIC top? Ford site only shows height for Base soft top of 73". Heights are the same for all models on the Ford spec list.
I have a garage height constraint of 76" and need to get firm specs before I order...
Toccoa
Isuzu Rodeo Sport
Tallest Bronco measurement I have for Badlands is 73.9” I got it off the spec sheet from Ford. Hope that helps.
Desert_6G
Phoenix, AZ
Ranger
Can't help with that. But you can find the height of the Wildtrack that comes standard with the hardtop and bigger tires
I think they specify "soft top" for the height. The hard top will likely be taller. Mine will be garage kept as well; and I refuse to buy one if I can't put a 2" lift on it and not be able to keep it in the garage.
jcmhere
Lacey
2015 Jeep and 1975 vett
Just so I am looking at the correct place what is the height of a WildTrack with the hardtop?
Toccoa
Isuzu Rodeo Sport
The 2DR is listed as 73.8 and it’s a hardtop. Wildtrak is listed as 75.3”.
HoosierDaddy
Indiana
Damn, why so short?
Old house or something?
timhood
Tim
Several
This might sound callous, but any reasonable chance of you converting that garage to a proper standard door? Not only would it help you, but it would surely help the resale value of your home.
If you aren't entering the garage perfectly level, you might lose a little bit of clearance as well.
Broncocito
B
NM
2021 Tacoma TRD PRO Manual
My inlaw's garage in Jersey is 6ft, but the garage inside is huge. Older homes are just that way or perhaps the OP is in a Condo with parking garage.
HoosierDaddy
Indiana
Posted by BronvoChicken
this is Sasquatch, so I guess you’ll have a little wiggle room
UGH, at only 1/2" clearance....aint no way I'd take the $50k gamble unless I could test fit it. I've seen tape measures with 1/4" variance between them.
You'll have to air down every time!!!! LOL
On 33"s you'll gain just over 3/4".... (34.4 - 32.7 = 1.7 / 2 = .85) So, .85 + .5 = 1.35" or roughly 1 1/4" clearance under your 76" door, assuming 100% door lift in the opening.
Mine will probably sleep outside for the time being anyways, until the 69 Bronco moves under it's own power again and can go to the storage unit in the winter.
Oh, I built in an 8' high door anyways.... ;) LOL
2Jeeps&PatriotX1
Denver, CO
Wow thats a low garage opening. I thought my 7’ door was low and I can still get my 6” lifted f150 on 35s in with a 1/4” to spare without airing down my tires. I only pull it in to do oil changes and other maintenance. My jeep with 35s and 3” lift clears with no problem, I just cant lower or raise the soft top with it in the garage and the garage door open.
