HELP! 4 door Tail gate Rattle
Broncoboyz
Nevada
2021 bronco
Well, my 4 door badlands SAS has developed a rather annoying rattle. I’ve tried sitting in the back while having a friend drive to identify where the rattle is coming from, and it seems to be coming from the spare tire mount itself.
I’ve tried using dry lubricant on each of the bolts without any success. Has anyone else experienced a spare tire rattle, and have found a fix?
thanks in advance!
j_marinelli
Spring Branch, TX.
Beach_Bum
Ken
St. Augustine, FL
Seems that the common problem is the bump stops for the spare tire. Remove the spare to see if the rattle goes away. If it does, then you'll have to adjust the bump stops to support the tire. Another member had to make custom bump stops as they were using a custom offset wheel. Good luck in tracing the source and getting it resolved.
Broncoboyz
Nevada
2021 bronco
ChristaLynne
Christa
CA
F-150
thanks in advance!
I am experiencing something similar and its driving me batso! I thought mine was the tire too, but rattle sounds like its coming from the hinge area? but i need to look at it again when I have more time. Seems to be getting worse. Please update me if you find it, and I will do the same.
Phil
Phil
2022 Tesla Model 3 LR
record the noise and post the video/audio and maybe we can narrow down for you
SamG
Sam
Detroit Area
sas
Yeah, record the noise.
My 4 door sas softtop makes ALL kinds of noise any time I hit any sort of crack in the pavement. Can't tell if its the softtop making sound of the rear gate.
Broncoboyz
Nevada
2021 bronco
I’ll do my best to get a video of the noise in the next day or so!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
thanks in advance!
Hello! Send us a private message with your Bronco's VIN and current mileage. I’d be happy to see what I can do to assist with this rattling issue. Thanks!
luptanpitman
Los Angeles
'21 Bronco, ‘21 Polestar
thanks in advance!
Same problem I just added a video of it on a particularly bad day to the other "gnarly... " thread. let you know if services comes up with solution tomorrow.
Kel
Kelechi
Houston
1971 Chevy
