Help-Installed Bilstein 5100s on Big Bend and too high
EagleBronco
New to Broncos and any type of aftermarket lifts. Have a Big Bend with stock 255s and wanted to run 315/70/17 tires so had a Bilstein 5100s installed and new Upper Control Arms. Mostly used as daily driver, live in Colorado and often on jeep roads camping and wanted more clearance.
Only looking for lift big enough to clear 315s, but Bronco came back too high. This is first lift they’ve done for a Bronco. Shop set Circlip at 2.9 front and 2.5 rear, level 5. The shop tells me a lower circlip level caused rear to be higher than front due to the original factory being 3/4” higher in rear (too much rake?).
After searching forum, it looks like level 2 or 3 would be closer to Sas height and what I’m looking for. When I asked shop to lower to level 2 or 3, they said it would rub due to wheel offset. (New Method 305 rims with 0 offset, I think. Stock Big bend wheel that came off was +55, I think.????)
Ford Bronco Help-Installed Bilstein 5100s on Big Bend and too high IMG_9145
Shop says I can go 1/2 lower total- The problem is the wheel offset. I want it lower than that.
Questions:
-What are my options now to lower lift?
- how noticeable is it if rear is set only 1/10th difference than front? When loaded w passengers or camping gear, will it look awful and hurt tire tread or maneuverability or anything?
-shoud I return wheels, if possible, and look for different offset?
Thank you!
Ford Bronco Help-Installed Bilstein 5100s on Big Bend and too high IMG_9144
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Looks great. My guess, crash bars need to be removed
Lak34ers
Troy
Seattle
Questions:
Thank you!
From the research and videos I watched seems around a 6-7 inch gap between top of tire and flare is "normal".
KABQ
Aaron
Albuquerque, NM
I agree about the crash bars. The shop may not know about them (their first Bronco), or were unwilling to remove safety equipment for liability reasons. Luckily they're incredibly easy to remove yourself and will eliminate any rubbing at sas ride height and 0 offset.
Sikexplicit
Joshua
Troy mo
24 bronco
I have 2dr bb with the 5100s set in the 3rd position stock bb wheels with 1.5" spacers and 315 70 sas tires crash bars removed. No rubbing whatsoever.
JimmyZ
Dawsonville, Ga. 30534
Bronco 2023
can you post a picture? side sot of your 2 door Bronco?
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Questions:
Thank you!
The "RAKE" is there for a reason...and looks much better than "SQUAT", which is the usual result of a leveling kit and gear in the rear! lol
Lex_310
Alex
Los Angeles
2024 Outer Banks
Shop is correct. If you were to stay with a more positive off set on the wheels closer to stock, then you could get away with going lower. You can still remove crash bars and go lower without issues.
