HELP-INSTALLED SAS SUSPENSION WITH LEVELING KIT ON NON SAS BIG BEND
Turkk22
Rich
LOS ANGELES
RX7 FD / Bronco
I NEED ASSIANTACE WITH MY BRONCO
MY BUDDY SOLD ME HIS SAS BILSTEIN AND LEVELING KIT SUSPENSION AND RECENTLY INSTALLED ON MY BIG BEND NON SAS
I NOTICE THE UPPER CONTROL ARM IS ANGLED DOWN AGGRESSIVELY IM RUNNING 33 TIRES WILL BE SWAPPING TO 35 ON THE WEEKEND
Ford Bronco HELP-INSTALLED SAS SUSPENSION WITH LEVELING KIT ON NON SAS BIG BEND IMG_0050
DO I NEED TO ALIGN THE CASTER ? SWAP OUT THE UPPER CONTROL? OR REMOVE THE LEVELING KIT?
Ford Bronco HELP-INSTALLED SAS SUSPENSION WITH LEVELING KIT ON NON SAS BIG BEND IMG_0051
Ford Bronco HELP-INSTALLED SAS SUSPENSION WITH LEVELING KIT ON NON SAS BIG BEND IMG_0052
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
I can't answer anything but, if you changed suspension, you need an alignment. As to what the UCA is supposed to look like with a leveling kit, I can't say, but it will definitely be angled more than it was.
Are both you and your buddies broncos the same door and engine configuration?
dgorsett
colorado
F250, Mustang, Explorer
How much spacer?
dgorsett
colorado
So, 2 + 1.1 (Sas)= 3.1. I'd say you definitely need an alignment. UCA will have quite an angle but those in the know sa the factory UCA has as munch range as most aftermarket. I'd say CV an tierod angles would be your biggest concern.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Have you driven it at all or is this immediately after dropping it back on the ground? It will settle a hair when the suspension cycles. The UCA angle still looks a lot better than what I'm dealing with having 4" of lift (2" more than I wanted).
Turkk22
Turkk22
Rich
LOS ANGELES
RX7 FD / Bronco
yes been driving it all weekend
is there a difference between non sas and sas UCA ?
Tricky Dick
Dick
PNW
Not that I'm aware of.
I did get Icon tubular UCAs but I don't think I really need them.
Turkk22
Turkk22
Rich
LOS ANGELES
RX7 FD / Bronco
update
so i found out the suspension had icon 3"" spacers
i removed them and everything feels better
