Hey guys,
I know a lot of OBX guys have discussed upgrading their 32s to 33s. We've touched on some tire specs, but never really confirmed what works.
I personally dont know much about tires and did some research/googling, and im coming up with the below. Anyone with a good understanding of tires care to chime in?
OBX stock tires - Bridgestone Dueller A/T RH-S 255/70/18 (32.1"). FYI i am seeing at $170/ea on tire rack
In an attempt to match what's on the Badlands, given its a 33. Badlands stock tires (this is for a 17" not 18" rim) are BFG TA K02 LT285/70/17 (32.7") - $258/ea
So given the OBX has 18" wheels, not 17" i should adjust the BFGs above from 285 to 275, so LT275/70/18? Tirerack says 33.3" (which is good, because if it was closer to 32.7" like on the Badlands, it may not be worth the upgrade over OBX stocks at 32.1").
So is that right? LT275/70/18? Keep in mind the OBX rim is narrower than the Badlands rim, so I am not sure how that comes into play, and requires another adjustment to the tire spec.
Thanks!
Thanks!
