It's no different that changing out the OBX suspension for the Badlands suspension, which is what I recently did.I’m very curious about your BL suspension swap in your Base, as I’m considering doing the same thing. Would you mind sharing what you paid for the BL take-off parts? Did you install them yourself or have a shop do it? Besides a realignment and headlight adjustment was anything else needed?
It takes the shocks, springs, and bump stops; all together I spent around $1500. I didn't need to adjust the alignment or headlights, but that was an OBX going to 33.5" tires. I did use FORSCAN to re-calibrate the speedo to compensate for the new tire size. I did my install myself, but if I had a shop that I trusted, I might have paid to have it done (even though I have a lift).
