help, procal fad delete, m190 to m210 swap
coffeetwitch
kansas city
bronco
hello,
im swapping to 5.13 gears and replacing my m190 with an m210 fdu. where is the fad delete option in procal?
thanks
also installing rock krawler 4 link conversion, does any know the tq specs for the jamb nuts and what the delta angle should be between the drive shaft and pinion? thanks again.
When you update the procal box on the computer it will ask you via a popup if you have upgraded to an m210. Then it will download the correct software with the tune file
Dusty
Mentone, CA
70, 71 & '21 Broncos
This threw me for a loop as well. It installs the FAD delete update with no further prompting (if you told it you are installing the new FDU). I was looking around for it in the menus in ProCal too LOL. BTW I have a video on this :)
coffeetwitch
kansas city
bronco
ok, so update... i havent updated my procal tool since i first installed tune. last night got it up to date and clicked yes to i have swapped fdu. today i did the tune. at first connection it wouldnt acknowledge that it was the bronco originally paired with it. kept pushing the tune button until it gave up and installed the new tune. then when it did the update for the fdu part, it stated failed. re did the tune update and on second time it went through. test drive and no dash lights so i guess all is good.
@Dusty
i like your install vids, they are honest. looking forward to the one about the 4 link convertion.
