Hi all,
I have an Outerbanks WITH the LED Tailights. I hooked up the Curt wiring harness and things are acting all wonky. I thought it was working but when the lights came on Automatically this a.m. things starting acting weird.
1. The turn signal blinks really fast, like when a bulb is bad.
2. The rear turn blinkers only blink when the light switch is in off mode. The turn blinkers are always on (both and not blinking) when the lights are on.
Any suggestions on where to start? I'm pretty sure I did it correctly and wired everything with the hot wire to the battery.
Could it be a ground? I was wondering if the white wire with the eyelet connector was grounded properly.
Thanks for any help or suggestions!
