Help with daytime running lights
Tuna Colada
South Carolina
BMW
Not sure if I am missing something but I have the daytime running lights turned on in settings and headlight switched to auto but no lights. Is there something else I need to do?
Thanks.
Lil Red Broncette
Explorer
Do the daytime running lights (probably just the headlights) come on and stay on during the day? II have them set to be on (believe it is the defult) but get no indication on the dash about them. I never looked at the front while running during the day so don't know that they do work.
The only time I see the green indication on the dash being on during daytime seems to be at times when the auto setting gets confused by deep shadows in otherwise bright day. At those times I notice the dash brightness change as it switches from full bright daylight to my dimmed down setting which I set at night.
Tuna Colada
South Carolina
BMW
They are supposed to come on and stay on during the day but don’t. I’ve see what you describe but I think if the daytime running lights are on there wouldn’t be any indication. Never had an indication in any other car I’ve had. Will take it to dealer so they can look at it.
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
Do you have the signature lighting? Or just the base lights? With the signature lighting the headlights don't come on for DRLs, only the rings around the headlights and the horizontal turn signal bars (all in white, not amber).
Tuna Colada
South Carolina
BMW
I have the signature lights- Badlands Lux- but there is no light at all with the DRL setting. No rings, no horizontal turn signal bars.
Brockdog12
NTX
2022 Explorer ST-Line
My OBX, set the headlight switch to automatic, DRLs will only light up when in gear. Green indicator lights on the dash are for headlight and fog lights on.
Tuna Colada
South Carolina
BMW
Very interesting. Hard to check your own vehicle from outside when in gear! Will have to see if it is only because I am looking at it in park. Never had a car/truck that worked that way. It was always ignition on- DRLs on.
Thanks.
Moto26
Tucson AZ
Yeah, might want to visually check it by driving up toward a store window before you bring it to the dealer...
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Thanks.
I've owned several vehicle that do not turn the DRL on until you put it in gear, then it stays on regardless of gear until you turn it off. If you are just starting it in park and looking at it, you may want to have it in gear to check. Easy enough to check at night from the inside as long as you are parked against something that will reflect the light when it comes on.
Tuna Colada
South Carolina
BMW
Thanks for the info. If I try to check at night, the auto headlights will be on already. Will try with someone standing in front during day.
kodiakisland
Arkansas
Yeah, checking that way at night might not work in the Bronco. I can turn on only DRLs in my Toyota and check it that way, but the Bronco may be all or nothing.
Brockdog12
NTX
Thanks.
Park in front of a window at a retail strip and put it in gear. Look at the back of the vehicle in front of you for your light reflection when stopped at a traffic light.
22OBX
Hartford, AL
That was the first thing I noticed in the “delivery bay window”. Start it up and I see no reflection in the glass and I’m like what? Put it in reverse and they came on. Whew. Crisis averted.
prospectfour
Pete
'22 Bronco, '18 Tiguan
Same for me. It was one of the first things I was looking for when I hopped in at the dealership. Sig lighting was one of the main reasons why I opted for OBX over BD.
