HoosierDaddy
Indiana
In my '98 Mazda B4000, the gearshift hit any taller beverages (16 oz bottles or tumblers) in the drivers cupholder when shifting into 2nd gear and the passengers in 4th. Swapping my beverage between passenger and driver cupholders just became part of the shifting process. Passengers just had to hang onto their beverage until we got on a highway.
I'd take that again if it guaranteed a manual in the Bronco.
Total win with this story. I can picture it perfectly. LOL
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
"As far as 4Runner, this should certainly be more 'fresh' of an interior, more powerful engine, and if it floats your boat, topless."
"If it's as capable as a 4Runner, or even a little more, that's pretty good company. 4Runners will go a ton of places."
"Yup. 4Runner is likely what I'll buy if this doesn't fit the bill for whatever reason. "
this, this and this ..... interior HAS to be wider than a wrangler or 4Runner it is :fingerscrossed:
TeocaliMG
Plymouth Michigan
www.brokeninnovation.com
My curiosity got the better of me...
I tried to do the best I could accounting for the perspective of the photographer and started by locating hardpoints. Then I marked the travel to "level" with a yellow box (because its easy to scale and rotate boxes for comparison). Then I have a white box for both the control arm length estimate and the tire radius.
If I assume the Control arm is 14" like Stampede said then I get more like 5" rebound, if I go by a very conservative tire radius estimate of 32" (it should be more) I get more like 6.5"
The truth may lie somewhere in between, or maybe better considering the tire and/or control arms may be bigger than the assumptions used here. Either way it doesn't look too bleak to me.
Ford Bronco Here's the 2021 Bronco's Tail Light Shape Illuminated 1582212346152
Carolina Jim
Highlands
2021 Bronco 2-door
You've looked at this in so many ways...both with the pride of a 'maker' and the enthusiasm of a 'buyer'. Having seen many pictures now, what's your best estimate of the 2dr/4dr wheelbases?
TeocaliMG
Plymouth Michigan
I made a drawing for that one as well, I think you can find it on the homepage. Not the best methodology mind you
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
Are you saying 6.5” of travel isn’t bad for an off-road vehicle?
Carolina Jim
Highlands
2021 Bronco 2-door
If you're still in the 116" camp on the 4-door....combining that with the 6g administrator promoting "Sunny Joe" to an 'eyewitness' on the homepage...I'm gonna guess the 2-door is @2-3 inches longer, and 3-4 wider than the 2020 Wrangler
TeocaliMG
Plymouth Michigan
No, I didn't bother to include an estimate for jounce travel which is hard to do without a lot of assumptions we don't have. Rebound is just the travel from ride height to full droop, that's what I was calculating. Given what the rebound is, I would be very surprised if the full wheel travel is less than 10" in any configuration, let alone this version
aplm7
Andy
Vacaville, CA
Explorer 2015
I think Ford is going for Toyota more than for Jeep haha, trick
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
10” will be comparable to a stock Rubicon, but still need a low speed sway bar disconnect to get full articulation.
Nanook
Jonathan
Thank you for the clarification.
That kind of wheel travel is impressive, most trucks have considerably less from the factory.
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
I've been trying to find hard numbers for the Ranger and Ranger Raptor front and rear wheel travel but I can't find them anywhere. Anybody have any ideas?
Tslater1989
Tyler
Central Michigan
2001 f150, 2016 explorer, 97 f150
From what I have found, ford hasn't published any numbers. Maybe in an effort to keep some secrecy to the bronco?
