High End Stereo Build Thread...
MNNTHBX
Tennessee
Big Bend, Scion iQ, Aprilia RS660, Ural
I'm about to dig in on what (to me) is a high end stereo install, and thought I'd document it so it may be of some help to others in the future.
Note: I'm not in the audio industry, but I've long had a passion for it, and running my current company (www.mnnthbx.com), I have plenty of design and fabrication ability. At 47 years old, I figured getting this new Big Bend was a good time to dive all in, and try to pull off the system of my teenage dreams.....
The goal is uncompromised sound quality, with enough power to deliver on a nice day with the top off. I'll actually get started on this, with updates in a few days, but here's most the list of the items now sitting in my garage (All from Crutchfield).
Advertisement
Slick85
Richard
Austin, TX
Nice! Everyone seems to love the JL W6 subs for great sound quality and SPL and the Hertz components have a good reputation as well.
MTmeterguy
Jeremy
Sidney, MT
2007 Ford F-150
I love Hertz components -- whenever my Bronco gets here I will be replacing mid bass with Hertz HSK (Hi-Energy) and I am going with Stereo Integrity's new carbon M3 up top. I have not decided on which direction for sub. Either an option like this or purchase the B/O enclosure and get the best 8" I can fit in there....That AudioControl amp looks like a great option!
I had a custom install done. I didn't want bass that would shake this thing to pieces, and I also didn't want to lose a single square inch of cargo space. I had a box made under my rear seat that fits 2 6.5" subs. I replaced all of my factory speakers as well and everything is running off a 900w JL Audio Amp now. The sound quality is unreal, and no one can believe these are 6.5" subs. Everyone assumes I have a 10".
I got to listen to the B&O system while attending the OffRoadeo, and I found that system to be absolutely nutless, especially with the top down. I went High Pkg instead and installed this system with the money I saved and could not be happier!
Bo-Ronco
Bo
HTX
2013 KR F150
Another phenomenal option is the Morel Virtus 603s. I have them in my Bronco on a JL Amp, and when i say there is no distortion... I mean NONE. They're so loud I feel like my ears are going to bleed when I crank it up but it's absolutely crystal clear whilst making me deaf! 🤣
MNNTHBX
Tennessee
Ok, baby steps, but here's an update, starting with some basic stuff....
Easiest power cable to run ever. There's a large and easy to remove grommet high on the driver's side of the firewall.
For the ground, there's a pre-existing M8 hole just being the plastic on the left side in the back...
It will require I end up sending 6 wires to the front, but I think I'll build a rack to hold these rather large crossovers inside the subfloor at the rear...
We drew up some 3" speaker adapters for the rear pods today, and printed them in carbon fiber...
Cut a hole in the lower flats of the pods to accept the tweeters, and mounted the Hertz 3's with adapters. Really happy with how this turned out....
Advertisement
gringoloco
Germany
on order
Looking good so far. Any updates this weekend?
MNNTHBX
Tennessee
Ok.... I've been a bit sick and lost a little drive, but we're moving again. I'm super particular with my stuff, so I cringe at the idea of cutting anything up, but I dove in and mounted the massive Hertz soft dome tweeter pods into the corners of the dash, using two push pins. They're super solid, and look pretty good to my eye...
I printed more brackets for the 3" Hertz mids and added a little boom mat gasket to kill any vibes off. Easy drop in affair...
The 6.5's went into some thick adapters I ordered online, from Sounds Good Stereo (or something to that effect).
Ford left plenty of room to run cables, and that's good, as I have 4 going up each site of the truck, plus the power cable...
With the front done, and taking a break, leaving this for tomorrow. I need to run the rear pod wiring down, and sort everything to and from the crossover rack...
CarbonBronco
Tony
Socal
99 Toyota $runner
This is an awesome build thread!!! Really looking forward to your thoughts on a 3 way setup in the bronco. I pulled my focal flax 2 ways out of my last rig to run in the bronco I really wish they made a focal flax 4” coaxial so I could fit it in the rear pods but I ended up with ac100 4” coaxials. I’m currently just wrapping up tuning power wire and should be re firing up my focal 5 channel again soon in the bronco. The stereo has been my biggest complaint in this thing. Who knows maybe I look into a flax 3 way if yours sounds as amazing as I think it will.
Slick85
Richard
Austin, TX
So you are putting rear fill in a two door? Is it because you typically have rear passengers or just like being surrounded by speakers?
MNNTHBX
Tennessee
No passengers. You always want rear fill. They'll be set to the appropriate level in the DSP amp.
Advertisement
Slick85
Richard
Austin, TX
Why 'always'? I had Focal components in a Tahoe previously and basically turned the rear fill off... from what I have read if you have top of the line components in the front you don't really need it...
MNNTHBX
Tennessee
It's personal preference, so if you prefer nothing in the rear, go that route. There's a reason EVERY stereo in the world has rear speakers, and it's not exclusively for people in the back....
MNNTHBX
Tennessee
Rear pods with some Boom Mat padding inside to deaden them a bit, wired, and mounted...
MNNTHBX
Tennessee
I'm probably not going to win many awards for wire management, but it's all secure and out of sight...
