Just wondering if others are seeing this same thing. As we are cruising down the highway, the highest trans temps that I have seen is about 201 F. However, when rock crawling in 4-low or going slow over rough terrain in 1st gear (4-high), the temps get up to 214 degrees. I assume the high temps are due to a lack of airflow over the trans cooler. I also assume that 214 degrees is on the high side of normal. But it is interesting to me that the temps get so high when there is not a lot of strain on the transmission. Anyone else seeing this or have any thoughts on whether or not this behavior is normal?
